Xh panelvan 5L conversion
 Post subject: Xh panelvan 5L conversion
Posted: Tue May 20, 2008 11:19 pm
Ride: xh panelvan
Hi,I'm new to this internet thing! I've got an xh panelvan and am interestd in dropping a 5L into it. Does anyone know if this can be done (and legally!!) I'm in Perth and would appreciate the help,cheers!!
Posted: Tue May 20, 2008 11:21 pm
Ride: ef xr8
Power: 229 rwkw
Can be done with ease.
Im sure legalites it wouldnt be too hard.
Because of Beer, Thirst is a Beautiful Thing!
'95 EF XR8 auto, Advance headers, 3" exhaust, Cobra manifold, BBK 75mm throttle body , 80MM Marauder MAF, Vortech V2 T Trim , 307 rwhp, 405 ft/lb 13.2 @ 105 MPH
Now N/A (permanent Lag) - AFR 165's, Comp XE270 cam, 1.6 RR - 269 rwhp 14.1 @ 102mph.
Posted: Tue May 20, 2008 11:29 pm
Ride: xh panelvan
Sounds good,is it as easy as a crossmember swap,or do i have to cut and weld some new mounts in? i sorta don't want the car off the road for too long!
Posted: Tue May 20, 2008 11:51 pm
Gallery: 15 images
Power: 236 rwkw
Keep a close eye on Petes (XR9UTE) thread in here about dropping the 5.0L into his XG. There will be some good information for you in there, although im pretty sure the steering/suspension set-up between XG and XH is different but it shouldnt be too much drama.
Im going to be really interested in this thread too, i have big plans (more like dreams) for an XH 5.0L Panelvan. :wink:
STREETBUILT RACING
Posted: Wed May 21, 2008 1:35 am
Ride: any modeL fORD fALCON 6 or 8
I've done 5.0L 4spd auto into an XG, XH will be a lot easier.. have a few shots in my gallery.
Have you driven a REAL Ford...lately?
Posted: Wed May 21, 2008 11:21 am
EFI Guru
Gallery: 28 images
Nope XH is much easier. You just need V8 mounts because EF-up and XH have the same k-member on 6 and 8. You won't have header hassles either. Did an AU220 engine into an XH many years ago running the AU EECV too. Easy.
Pete.
Posted: Wed May 21, 2008 11:28 am
Ride: T1 TE50 P01
Welcome to the forums,
As mentioned by several ppl above, its a straight forward swap.
It might be worth getting a donor car, or hunt the wreckers for a low km engine/trans. EL2 onwards would be preferable, AU3 220kw even better!
TE50 T1 P01
Posted: Wed May 21, 2008 8:04 pm
Ride: XR6
I have recently done this to my ute, like said just need change engine mounts and need computer and wiring loom change and 6 gearbox wont fit to the 5L but yea its not to hard
 Post subject: Re:
Posted: Sun Jan 06, 2019 11:49 am
Gallery: 12 images
Ride: DCII LTD V8
Massive thread mine, but question on the wiring loom change.
How hard is it to graft an EL V8 sedan loom into the ute? Or what's the easiest loom to put in the XH? Manual so don't need a loom with TCM.
Trick Flow Heads/Cam/Intake, Crane Ignition, T5Z Trans.
 Post subject: Re: Xh panelvan 5L conversion
Posted: Sun Jan 06, 2019 12:06 pm
EFI Guru
Gallery: 28 images
EL harness is not difficult to do. Btw I’m about to do a BA pcm into an XH running a 393/BTR. That’s more effort.
Posted: Sun Jan 06, 2019 12:16 pm
Gallery: 12 images
Ride: DCII LTD V8
Do i just have to loop the rear door wires and things like that? Mechanical side of things im sorted, trying to get my head around the wiring.
Posted: Sun Jan 06, 2019 1:28 pm
EFI Guru
Gallery: 28 images
I was talking about splicing the engine related harnessing into the XH harness. What you’re talking about is probably easier.
Posted: Tue Jan 08, 2019 4:54 pm
Gallery: 12 images
Ride: DCII LTD V8
Is it possible to splice the v8 engine harness into the existing XH loom along the engine bay firewall? Definitely appreciate the guidance.
Posted: Tue Jan 08, 2019 5:01 pm
EFI Guru
Gallery: 28 images
You do it in the dashboard harness. The main one being the rectangular white connector near the A/C box behind the glove box.
Posted: Tue Jan 08, 2019 5:43 pm
Gallery: 12 images
Ride: DCII LTD V8
So what you're saying is, I can use my existing v8 injector loom and graft it into the XH i6 dash loom, plug in an EL V8 ECU and that's the wiring done? Sounds too easy....
Been trying to sell the LTD, but hasn't had any interest so the ute may end up with the 302 and T5 after all...
It is currently Tue May 20, 2025 12:24 pm All times are UTC + 11 hours
