EF 5.0L - power steering pump/pully removal?
Page 1 of 1 [ 6 posts ]
 Post subject: EF 5.0L - power steering pump/pully removal?
Posted: Sat Apr 16, 2022 2:03 pm
Ride: Barra XF - 11TO8cZ5.0l EF
How on earth do you take the power steering pump out of a ef v8? Do you need to remove the pully first??? And the next question would be is the Allen key bolt in the middle of the pully left or right hand thread? ?? Any help would be sik
 Post subject: Re: EF 5.0L - power steering pump/pully removal?
Posted: Sat Apr 16, 2022 7:30 pm
Online
no idea! .............................. can have a look at the EF V8 sitting here tomorrow for ya?.
Posted: Sat Apr 16, 2022 11:41 pm
Yes pleeease, any help or suggestions would be awesome!
Posted: Sun Apr 17, 2022 4:02 pm
Online
wellll ............ i'm not much use :roll: got a 10mm spanner on the two bolts holding the upper of the pump to the bracket .. & spanner slipped :? so it's burred 'slightly'. might ask on another forum.
Posted: Sun Apr 17, 2022 4:40 pm
Online
ok .... did a better search :roll:
you will need to remove the pulley 1st & you will need such as in link to remove/refit
this [or similar] will allow you to remove pulley & then you will be able to easily remove the bolts holding pump in.
Posted: Mon Apr 18, 2022 7:52 pm
Online
also links i found to fordmods.....
and
Users browsing this forum: No registered users and 36 guests
It is currently Sat Jun 21, 2025 5:05 pm All times are UTC + 11 hours
