kenny |
with the idler pins/shafts on a windsor, should they have a clearance between the timing cover, I would assume they should but not too much,
the reason I ask as am fitting one to my xr8 but got the early windsor model as I was told they were no different by the supplier, well they are! the shafts seem about 1/2'' longer ,and I have access to machines to shorten them, just a little unsure about the length to make them? any help would be gr8, cheers kenny
EBXR8380 |
When I got my first E303 cam it came with two pins, I think I used the shorter pin???
But there IS different size depending on block...Doesn't this pin fit under washer that holds cam sprocket there ?? Edit I see you are using gear drive...
