Injectors, Injectors, Injectors !!!
Page 1 of 1 [ 9 posts ]
 Post subject: Injectors, Injectors, Injectors !!!
Posted: Fri Dec 24, 2004 10:09 am
Ride: No fords at the mo' :-(
Guys,
I am now looking into injectors for the ED V8
Std is 19lb / hr isn't it? What colour are they?
Would see a gain in performance if I go to 24lb / hr with the correct MAF set up on a standard cam? What colour are they?
For someting like a crane 2020 / 2030 or similar ... should I consider bigger than standard? If so how much?
Finally. with a 392ci in the pipeline .... should I consider 30lb / hr or maybe 36 lb / hr?
Cheers,
Chasing 162mph on the Salt! 4.2L. Both race cars now sold! :-( Maybe a small-block tractor puller! or a Lotus 7 Clubman is next! or a 351-stroker powered EB ... ?
Site Admin
Ride: AUII V8 LTD
Power: 270 rwkw
The Ford Motorsport 24lb/hr injectors are Blue :)
Posted: Fri Dec 24, 2004 10:44 am
Gallery: 14 images
Ride: NL 347, Landau
Standard Ford 19lb/hr injectors are orange tops
24lb/hr injectors are blue tops
30lb/hr injectors are red tops
42lb/hr injectors are flouro green tops.
Changing injectors alone on a standard motor won't make you power - but if you upgrade from the HO intake/E7 heads to Explorer/GT40 or better and change cam and exhaust - the 19lb/hr injectors will start maxing out on their duty cycle and lean out (which is why the Sprint's, GT's and later AU's had 24lb/hr injectors)
Shane
Weapons of choice
1998 NL Fairlane by Tickford 033
1996 NL Fairlane Ghia 347
1992 NC Fairlane Ghia 5.0
1974 Landau
1974 LTD
Posted: Fri Dec 24, 2004 10:47 am
Site Admin
Ride: AUII V8 LTD
Power: 270 rwkw
Out of interest, where do the Black Top EB-EL 4L injectors fit into the equation ?
Posted: Fri Dec 24, 2004 11:01 am
Gallery: 37 images
Ride: V8 EF Futura
I was always under the impression the 4L ran a 19# injector....
Posted: Fri Dec 24, 2004 11:36 am
Site Admin
Ride: AUII V8 LTD
Power: 270 rwkw
Me too, although someone has raised doubt in my mind recently.
I've heard a few people refer to them as 21lb/hr. If they were 19, why aren't they orange tops like the V8?
Posted: Fri Dec 24, 2004 1:16 pm
Ride: NL V8 Fairlane
I'd like to know also as I've been told the black ones are 21 or something like that.. A bit odd.
Posted: Fri Dec 24, 2004 3:46 pm
Power: 482 rwkw
I can only assume the 6's are from Aussie as the V8's have U.S backing...
When flow rates are measured always check the fuel pressure they where tested at , most Ford injectors are run at 38 Lb but other manu at 40 Lb...
As in ZOOM 126 edition
Posted: Fri Dec 24, 2004 10:48 pm
Ride: XR6 Turbo, XR8, Transit
I only recently upgraded to 30lb injectors, they look more of a maroon colour than red.
When I was running the 19lb injectors, my car was happily making 185rwkw, but started to lean out when I got the new heads.
If you have big plans for your motor, get bigger injectors, if you are just going to do exhaust, cam and chip, leave the 19's.
1993 ED XR8 - Poly Green
2006 BF GT - Silhouette Black
2011 FG XR6 Ute - Nitro Blue
It is currently Sat Jun 21, 2025 12:46 am All times are UTC + 11 hours
