crane 2031
 Post subject: crane 2031
Posted: Fri Dec 17, 2004 6:57 pm
can anyone tell me if i could run the crane 2031 cam with auto and stock converter...running AFR 165's and modified explorer manifold
Posted: Fri Dec 17, 2004 9:40 pm
Ride: EB V8
xr8 chic uses this cam, and with 185s and perf rpm intake. ask her what it's like.
Production Editor of Performance Motoring at Express Media Group
shollier@expresspublications.com.au
Phone: (02) 9741 3838 (direct line)
Posted: Fri Dec 17, 2004 9:48 pm
Ride: NL V8 Fairlane
Good cam, not that lumpy and ideally used with 1.72 ratio rockers. :P
Posted: Sun Dec 19, 2004 12:44 am
Power: 482 rwkw
Cannot go wrong with this cam..But upgrade springs....
As in ZOOM 126 edition
Posted: Sun Dec 19, 2004 2:45 am
Ride: 320kw BA XR8
As said, great cam and will work fine with stock auto stall. It is suppose to idle nicely but some people (mainly later madel ie AU's) have idle problems.
Posted: Sun Dec 19, 2004 3:35 pm
Ride: XR6 Turbo, XR8, Transit
Yeah - good cam.
As EBXR8380 says - upgrade your springs!!! (and make sure the upgraded ones actually get into the engine, and not in someones tool chest).
I had a few idle problems (as in the fact that it wouldnt idle at all - but I was running stock manifold, and ported E7 heads at the time).. but it was sorted out with a reprogram of the unichip.
1993 ED XR8 - Poly Green
2006 BF GT - Silhouette Black
2011 FG XR6 Ute - Nitro Blue
 Post subject: Re: crane 2031
Posted: Sun Dec 19, 2004 6:22 pm
thanks for the replies guys and girls...i just might go with this cam...if this car is an every day driver would you still recomend it...?
Posted: Tue Dec 21, 2004 1:29 am
I have had that cam in my car XR for 3.5 years now.
She was my daily driver till last christmas, when I killed the motor again... and had to buy another car while she was getting rebuilt.
so yeah - its good for a daily driver.
Posted: Tue Dec 21, 2004 9:48 am
Ride: R33 GTS-T
Why do AUs have idle problems with the 2031?
Hope is the first step on the road to disappointment.
Posted: Tue Dec 21, 2004 9:53 am
Ride: 320kw BA XR8
Don't know why, obviously something in their EEC programming.
Posted: Tue Dec 21, 2004 1:07 pm
Maybe its the same reason why ED's have idle problems with it.
:P
most cars I know with cams have idle problems. It just hunts a bit - no biggy
Posted: Tue Dec 21, 2004 1:50 pm
Ride: 320kw BA XR8
:P
Both cams I have run have been larger than the 2031 and both idle fine. I also know 3 others running 2031/2030 cams in their E-series V8's and they idle fine too so I think it's just hit and miss. Even if they idle bad, there are always ways to get the idle back to normal, just have to find out why.
Posted: Tue Dec 21, 2004 4:19 pm
Power: 482 rwkw
Bassically with bigger cams they need MORE air to idle and need to idle slightly higher..The old method around this was to drill a hole in butterfly..Notice std 55mm had a hole in b/f but my Cobra 65mm didn't...The other way around this is to open throttle position and adjust tps back to under 1v koeo..Too low rpm means low vacuum which plays havoc with eec, it thinks its under load with low vacuum then corrects causing surge....Right Pete ?
Posted: Tue Dec 21, 2004 4:53 pm
yep... mine was relatively easy to fix (just took my tuner a few attempts to get it perfect).
Used to be good fun, as I could recognise when the car was going to stall, and correct it. but anyone else who tried to drive the car would stall it a few times.
hehehe
Posted: Wed Dec 22, 2004 10:10 pm
Also how is the 2030 compared to the 2031... as the crane 2030 uses 1.6 ratio rockers therefor less valve guide wear...
Users browsing this forum: Google [Bot] and 19 guests
It is currently Thu Jun 19, 2025 2:38 pm All times are UTC + 11 hours
