Bsjenko |
i know this has been posted plenty of times, but i did a search and just couldnt find exactly what i was looking for.
on the weekend i will be doing service on the car... ![]() what do u recommend? i have read about 9mm and 10.5mm leads, with the only difference in 10.5 having more insulation. what advantage would this have? what would be a good brand to buy? and how much approx? plugs, are the standard NGK plugs anygood that u get from any old atuo parts joint, just the standard ones? i dont think i will go the ones that last ages, as i cant justify the price.. oil and filter. What is the best oil to use, i use to use shell red (cant remember the name) oil in the old Eb, but didnt overly impress me. And what oil filter should i get, i heard the standard ones from ryco are complete s**t. but not sure or any other brands. Coolant, what coolant do you reccomend? i used to just use the s**t $5 s**t,but i wouldnt mind getting something a bit better. cheers boys
_________________ The Lane Lives.... Finally!!!! |
chunkz |
oil - i just used magnetec...
with spark plugs make sure you check the gap.. everytime i get a packet that say they are made for the car, always have the wrong gap.. so check the gap.. coolant, umm castrol (i think its them) have a good one
fairmont1998 |
10.5 mm leads would be a waste of time on a mostly stock motor, I'd stick with the 9mm leads and save some money.
I use the standard NGK plugs and have no trouble with them either, good plugs and I can live with replacing them more frequently. Strange you've heard negative comments about the Ryco oil filter. I've never heard of them being bad, I've always used a Z9 Ryco and have been happy. Oil wise, don't go for anything too thin. I use the semi-synthetic Shell Helix, not sure what colour bottle that is, think its the silver one. Get some good coolant in there too, give the motor and radiator a flush and fill it with Tectaloy 90+ or something equivelant. I only buy the premixed ones, I won't let Adelaide water anywhere near my cooling system!
_________________ 2008 WQ Fiesta XR4 |
Johnson stroker |
yeah grab the castrol concentrate coolant on the little ring pull tin..
oil, you get what you pay for, or are you asking what grade, and yeah check the gaps, also when you put your wheels back on if tou take em off make sure you put on the right way.. (chunkz knows this one) sorry mate its still going.
xpression |
oil filter i always use genuine stuff, even a genuine AFL 1 MC filter retails for less then $10.
plugs, as has been said the NGK ones are okay, but yes make sure u do check the gap. leads - if there is nothing wrong with your existing leads what do u hope to gain by changing them? coolant - again i'd use genuine, but other decent stuff should be okay, make sure u actually flush the cooling system as opposed to draining and refilling it. |
Bsjenko |
the leads that are on it are the original leads... so i think it is time for a change, seeing how it will be 8 years old next month.
and yeah what grade oil to use would be great.
Oldm8 |
In Australia you don't really need a thin oil.
I use 15w50 in mine. I use the Valvoline Durablend. With filters any of the known brands are decent. Such as Ryco. I use a Fleetguard LF3487. It's not paper media it uses Microglass (synthetic). It's overkill on a Pushrod 5Ltr but ever since Dean Canto started bying them off me a few years ago for his race cars i figured i may as well use 'em since i pay stuff all for 'em. Leads are a waste of money unless they are busted or you're building a big Hp motor. I'd use genuine or Iridium plugs for the fact that they're a pain in the a*** to change on the 5Ltr engines. Check your belt, tensioners and idler pulleys. They wear a fair bit. Have fun. ![]() |
xpression |
factory spec is 15w/40 or 20w/50 so i certainly wouldnt put anything thinner then 15/40 in a stock engine, but yeh. i'd run 15w/40.
Users browsing this forum: No registered users and 22 guests |
