Straight cut timing gears / Noisy or Quiet Gear drive
 Post subject: Straight cut timing gears / Noisy or Quiet Gear drive
Posted: Thu Aug 24, 2006 11:35 pm
Ride: V8
Just found this on ebay
http://cgi.ebay.com/ebaymotors/302-351- ... enameZWDVW
will both the noisy or quiet gear drive option fit on EB-AU 5.0s? Or are these only for the oldschool 302 windsors. Will the ECU stuff up if I put this in? Any gains even if its 0.5 kw?
Posted: Fri Aug 25, 2006 12:08 am
Gallery: 5 images
Ride: AU Fairlane 5.0, KE Laser, 01 Kw
Going back years ago a lot of guys wouldn't use them, one of the main reasons was if the engine back fires the chain gives, gears don't!
I knew a lot of guys in drag racing back then, nobody used gears.
His rollers aren't bad for $340 aus inc shipping.
Posted: Fri Aug 25, 2006 12:55 pm
EFI Guru
Gallery: 28 images
late 5.0's need a spacer between the end of the cam and the gear.
If I were to use one I'd use single idler type.
If you really want the ultimate use a belt drive but they cost lots and need a special timing cover which is why they cost lots :wink: .
Pete.
It is currently Sun May 18, 2025 12:53 am All times are UTC + 11 hours
