aftermarket MAF for windsor
 Post subject: aftermarket MAF for windsor
Posted: Sat Aug 12, 2006 7:08 pm
Gallery: 9 images
Ride: EB Fairmont V8
What is the best aftermarket MAF solution for an EB I windsor?
Thanks
Pat
Posted: Sat Aug 12, 2006 8:43 pm
get a Pro M MAF, think that's wat most windsor owners opt for. there's also C & L which is popular too. Im after a Pro M maf and 24's for my EL now. Try the corral forums or ebay.com
Posted: Sat Aug 12, 2006 9:19 pm
Gallery: 12 images
Ride: au xr8 & 5.0 eb
ive got an eb1 5.0 and ford disconected it and said it shouldnt have one as it has an air flow meter???? dont know but its been like it for years and runs well,dont know its all over my head im a carby man lol
Posted: Sun Aug 13, 2006 11:35 pm
Gallery: 17 images
A MAF is an air flow meter. Also Pro-M and C&L are pretty much the same thing - C&L had Pro-M manufacture part of their MAF range. You'll need one with the flange though and most in the US are non-flanged, unless of course you are going to run a pod filter.
Posted: Mon Aug 14, 2006 8:20 pm
Gallery: 12 images
so because my airflow meter is in the pipe from the air filter whats the other thing on the firewall with wires and (used to have vacume)going to it i allways thought it was a maf sensor???
Posted: Mon Aug 14, 2006 9:16 pm
Gallery: 17 images
That would be a MAP (manifold absolute pressure) sensor.
Posted: Mon Aug 14, 2006 11:01 pm
Ride: ebxr8
on the v8's its called a bap sensor (barometric absolute pressure sensor)
347, crane cam, Pro topline 180 heads, Edelbrock victor efi intake, 80mm C&L maf, 75mm tb, 30lb injectors and 1/4 horse
Posted: Mon Aug 14, 2006 11:50 pm
Gallery: 9 images
Out of interest would it be possible to apply a later falcon MAF to an EB windsor? Would this be a benefit?
Just wanted to know if there is a cheaper option
Posted: Tue Aug 15, 2006 3:51 pm
Ride: EL Fairmont Ghia V8 Turbo
Power: 303 rwkw
65mm AU ones hook straight up, just swap TPS.....you really wont see much gain if you don't do your intake though
EL Fairmont Ghia V8 Turbo 303rwkw
Posted: Tue Aug 15, 2006 4:18 pm
EFI Guru
Gallery: 28 images
Series one EB 5.0's have a BAP sensor. It looks like a MAP sensor because it is the same sensor left open to measure Barometric Absolute Pressure not Manifold Absolute Pressure(MAP) as it does on all sixes.
Pete.
Posted: Tue Aug 15, 2006 7:53 pm
Gallery: 9 images
Offyaguts - would an AU MAP/BAP improve much on the stock one?
Pete - Do you think it is worth doing this mod if I go for an AU MAP/BAP?
My plan was to -
K & N filter
stainless intake pipe
EL GT Snorkel
and upgraded MAP/BAP
Is this the way to go? Would like to do it all in one hit... so thats air taken care of.
Cheers guys
Pat
Posted: Tue Aug 15, 2006 10:29 pm
Gallery: 12 images
Pete.
thanks for that it clears it up a bit,someone tryed to tell me it used to be a 6cyl because of it not being hooked to the manifold but it must just be a series 1 thing,lol i dont really care i never have to lift the bonnett on the old girl it just keeps going thats why ive still got it,best car ive ever owned by far (and probally the slowest lol)
Posted: Wed Aug 16, 2006 12:12 am
EFI Guru
Gallery: 28 images
There is no reason to use an AU MAP sensor they do the same thing...read barometric pressure.
Certainly use the AU MAF with the hotwire off your original MAF....it reduces inlet restriction. It's not perfect, sometimes an adjustable fuel reg is required but you can get away with it in most situations.
A TwEECer will allow you to make it perfect because you'll be able to program in the exact MAF transfer function or even make your own MAF transfer function.
Cheers Lads,
Pete.
Posted: Wed Aug 30, 2006 1:12 am
Gallery: 9 images
Where can I learn more about this TwEEcEr Pete?
Pat
Posted: Wed Aug 30, 2006 11:18 am
EFI Guru
Gallery: 28 images
Pat
Hi Pat,
From me. Send me a PM with the catch code from your EEC.
Cheers,
Pete.
Users browsing this forum: Google Adsense [Bot] and 15 guests
It is currently Sun Jul 13, 2025 7:06 pm All times are UTC + 11 hours
