Manual Engine Loom vs. Auto
Page 1 of 1 [ 5 posts ]
 Post subject: Manual Engine Loom vs. Auto
Posted: Wed Sep 06, 2006 8:49 pm
Ride: BOXCAR
Are the manual engine bay looms any different to the auto engine looms in the EL range?
^^^ What He Said
Posted: Wed Sep 06, 2006 10:30 pm
Ride: Ford FPV FG F6 310
Power: 149 rwkw
i think they are, for the fact there is no neutral/park switch and auto wiring.
Posted: Thu Sep 07, 2006 1:57 pm
Ride: EBII 220kw Tickford powered.
Do you mean the engine loom or the ECU loom?
The gear boxes plug into the ECU loom. The ecu units itself are different between manual and auto.
The g'box looms are the same, with a jumper put in for a manual box, to override the neutral cutout function.
The engine looms are the same.
The car should be called "Frankenstien". EBII GLi skeleton, AU T2 220kw heart, AU2 brain, EF/EL for everything else.
"Bitza" Member 28 on FORDMODS v1.0 Joined 28-04-2002
"TS50EB" Member 300 on FORDMODS v1.1 Rejoined 6-11-2004
Posted: Thu Sep 07, 2006 6:54 pm
Ride: BOXCAR
So the engine loom is the same between manual and auto. Got that.
My next question is: is the AUTO ECU loom the same as a ED one?
Posted: Sat Sep 09, 2006 12:14 am
Ride: BOXCAR
bump...anymore help?
It is currently Wed Jul 09, 2025 2:34 am All times are UTC + 11 hours
