Mac Winter 76XB351GS |
Gday,
I have the MSD ready to run billet electronic ignition. It says in the manual that it can use the MSD multispark ignition systems. I was looking at the http://www.msdignition.com/ignition_6_6420.htm , Just wondering what kind of gains this would give and if its worth the $400 or so. I havent decided if I really want it yet, this model seems more suited to drag applications but it is just a rev limited version of the http://www.msdignition.com/ignition_4_6200.htm which promises power gains and better economy. Im just after a streeter, I dont go down the strip, currently have a 351c with a crow 21666, extractors into 2.5" twins, port and polish with EVL valves and springs, edelbrock performer intake and 750 holley vac sec. Thanks.
_________________ 76XBGS, 383c, custom crow cam, 4V p&p heads, Isky SS Valve+springs, extractors, 2.5"twins, MSD Ignition, Edelbrock intake, Forged bottom end, Barry Grant 750DP, thermo, discs, toploader, Holley fuel pump, SUPERCHARGED! |
EBXR8380 |
They are bassically the same...The L has the rev limiter.. If you don't have rev limiter ? Then I'd get the 6AL..
Thats the only difference I could spot too. Is there much benefit to multispark over a standard spark from my electronic ignition?
EBXR8380 |
Like most things like tuneing an engine.. Its realy worth it IF it needs it...But imo I'd fit it...
The multy spark and dissy didn't work for me due to having such low compression [7.8] I could run heaps of advance which caused havoc with crossfire in dissy cap. Also made worse by having a bloody good long spark dwell.. So in my case I went to DIS / wasted spark system.. I will be soon fitting MSD DIS 4 to feed all 4 coils...
Ok fair enough. Im running 9:1 I think. Should be getting the proper hei leads next week, hopefully that cuts back on any crossfire. Im not too sure about the dwell though. I should have everything running tomorrow if I can find a timing cover oil seal and a set of good intake gaskets on a sat.
Users browsing this forum: Google [Bot] and 13 guests |
