MICKYYYY |
Ive been told the reason why my air conditioning is not working is becuz my trickflow manifold is not connected to the vacume air conditioning system and it only stays on windscreen setting and it will not change to feet and so on.
Now if this is true how can i get back my air conditioning? PPL with aftermarket intakes please give me some advice on how to get my airconditioning working properly? Thanks in advance to all ![]()
_________________ Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc[/SIZE][/size][/color] |
TerroristGHIA |
Find an input for the vacuum line and hook it up. May have to get a fitting drilled into the manifold, but shouldn't be to hard.
Brett
MICKYYYY |
Cool, ill ask the air conditioner guy if he knows about that. I was thinking that i would have to drill into the manifold to get vacume but the thing is were is the best part on the manifold to do it? and or is there a spot where it must be drilled to get proper vacume?
Krytox |
surely theres provision somewhere!
add a 'T' to the brake booster. and also add a one way valve if there isn't one.
MICKYYYY |
MMMMMMMMMM u guys are on to it, thanks heaps. Im not that technically minded so im just gona print this stuff out & show my electrician/ air conditioner guy and see what he can do for me.
Lucky he knows me as he does not like working on modded cars anymore so he said he will do the best to help me out ![]()
XR9UTE |
TFS intakes should take the stock vacuum tree that's on the stock intake unless you have a box upper TFS-R which have several vacuum nipples around the plenum. No reason why you should'nt be able to hook it up as normal.
Pete. |
MICKYYYY |
How many vacume values are there?
I may have to rip the manifold of & get a mate of mine to look @ it. I just want to get this thing working.
