blown head gasket
Page 1 of 1 [ 12 posts ]
 Post subject: blown head gasket
Posted: Thu Mar 01, 2007 3:59 pm
Gallery: 14 images
Ride: ebxr8
Can anyone shed some light on why my 347[1000k's since rebuild] has blown a headgasket while on the dyno @ around 4000rpm,my tuner thinks that maybe since my builder had the motor retarded 20 degree's to get it running on the stock eec,that this would put an extreme amount of heat thru the heads and exhaust ports thus has probably weakened the gasket.
any thoughts true or false. :!:
Posted: Thu Mar 01, 2007 4:04 pm
Ride: EA svo turbo, ef Fairmontl
could be true, but still after only such a short number of kays id be asking some questions!
R.I.P George.D.Gogas!!!
4.5.85 - 27.2.05
Posted: Thu Mar 01, 2007 4:10 pm
Gallery: 14 images
Ride: ebxr8
my engine builder was asking how hard was the tuner pushing it,but the tuner assures me it was no more than 4000 as we will go higher revs later when i have more k's on it.
at least its getting fixed on warranty.
Posted: Thu Mar 01, 2007 5:58 pm
Ride: NF Fairlane V8
Bit of a bummer that!!
Which Cyl went bang ??? If it was one of the back ones (4 or 8) then there's a good chance that it is a head gasket back to front (not hard to do even by experienced builders).
Only real way to tell is to pull the head off and see where the gasket failed, but if it's under warranty then I guess you'll have to see what they say..
The TORQUE Monster project begins!
Pic's, details and all the yummy stuff:
"There's no replacement for displacement!"
Posted: Thu Mar 01, 2007 6:00 pm
Gallery: 23 images
Ride: XR6 Turbo
head gasket placed on incorrectly?
SS Inductions CAI, K&N Filters, M-spec FMC, Turbosmart BOV, 8psi capa tune, X-force cat.
Mods going on: Nizpro springs, bosch 040 pump + Walbro gss341, 600cc injectors, PWR transcooler, 20% Underdrives, 15psi Actuator, Kingspring SSL's, 15psi tune.....More coming
Posted: Thu Mar 01, 2007 6:10 pm
Yep they only have holes on one end for the coolant but they can be put on upside down.
The block and heads have coolant holes at both ends so if your not paying enough attention when putting em on it's easy to do them back to front. :D
 Post subject: Re: blown head gasket
Posted: Thu Mar 01, 2007 11:54 pm
EFI Guru
Gallery: 28 images
Questions;
Why would he need to retard it so much(I assume you mean ignition timing?) to get it running? If he did that suggests other problems.
Was the A/F ratio logged when this happened? How much load was it under when the failure occurred?
What are the rest of the specs of this combo and I mean everything?
Cheers,
Pete.
Posted: Sun Mar 04, 2007 1:39 pm
Ride: xlsv8ute
NfGia, if you put the head gasket on wrong it wouldnt last 5 mins let alone 1000ks. 20 degrees retarded, or is engine builder retarded :roll:
go the CROWS
Posted: Sun Mar 04, 2007 4:27 pm
Power: 113 rwkw
Also did u use the s**t ford head gasget or a felpro or ?
Im a dodge /val man now a ford person, (HATE HOLDEN)i have built many val 6 and v8 motors and found if you use a stock head gasget when you have moded the moter you will find it will s**t itself i have always been a fan of felpro head gastets as stock ones are a wast of time and money.
If you are a fan of your car you will always use the best as in the end if you cut costs you pay doubble in the end.
BANNED
Posted: Sun Mar 04, 2007 5:48 pm
Ride: xlsv8ute
Yep I used felpro head gaskets and head bolts when fitted a set of worked gt40ps to my car a week ago. no probs so far :)
go the CROWS
Posted: Sun Mar 04, 2007 6:01 pm
Gallery: 14 images
Ride: ebxr8
I'll know mon-tues on the cause of the prob,my engine builder thinks its to do with pre-detination or car was too lean for the first 1000k's of running it in,said it should have been tuned earlier,not happy but he will fix for me at no cost,i'll post cause when i find out.
Posted: Sun Mar 04, 2007 8:57 pm
Ride: 93 ED sedan
Power: 161 rwkw
Geuine Ford gaskets are Felpro gaskets for starters, and did the rebuilder guy use new head bolts.???
If I remember, the head bolts must be replaced, same as the Explorer engines, and Taurus engines. Damn "Torque to yeild" sh!t bolts.
Another one is to be careful not to get oil on the gasket surfaces when bolting it down, from the bolts being oiled.
Trick is to pull down the head with the bolts dry, to about 20lb/ft, then one at a time, take them out and put oil on the threads.
Never had a problem doing it this way.
http://youtu.be/jJTh9F3Vgg0
Users browsing this forum: No registered users and 27 guests
It is currently Fri Jul 11, 2025 12:30 pm All times are UTC + 11 hours
