Crane roller camshaft sr288
 Post subject: Crane roller camshaft sr288
Posted: Sat Jul 21, 2007 3:50 am
Gallery: 35 images
Ride: xy fairmont
Hey all.... cant find any info on the crane roller cam sr288 if any won can help would be very greatfull...cheers .....ive looked everywhere and cant find a thing no referance numbers seem to go that high??? ( buti have one in my motor)??????
If you have it under control then you dont have enough power..
There is no replacement for Displacment..
Posted: Sat Jul 21, 2007 12:18 pm
Gallery: 5 images
Ride: AU Fairlane 5.0, KE Laser, 01 Kw
I just done a quick search and found nothing, seems like it doesn't exist.
You might have to take it somewhere and get a profile done on it.
Or call Crane in the states and see what you can get out of them.
 Post subject: are u sure
Posted: Sat Jul 21, 2007 10:45 pm
Ride: ef XR8 / xe fairmont ghia 393.
are u sure its not this... closest i could find
SR-238/350-2S-12 MECHANICAL SPECIAL 1970-1982 FORD-MERCURY V-8 BOSS 351-351C-
351M-400 CU.IN.
Ef xr8. Charged 9psi, tw 170 heads,track heat intakes,1.72 rockers, f303 cam, custom plazma man/ rapid cooler, 60lb injectors, tko600, sct eliminator, aeromotive fuel system.
393 xe ghia stage 5 als raceglides c4,9" full spool 31spline moser axles. Will be looking at running high 9s low 10's
Posted: Sun Jul 22, 2007 2:39 pm
Gallery: 35 images
Ride: xy fairmont
this is the number the enjine builder gave me and ive seen the specs in a crane cam book they have but i just cant find it on the net...??? ill double check i may have writen it down rong but i dont think so cheers any way Guys..
It is currently Sat May 17, 2025 11:47 pm All times are UTC + 11 hours
