Red water jug with fan light illuminated - cooling issue?
Page 1 of 1 [ 15 posts ]
 Post subject: Red water jug with fan light illuminated - cooling issue?
Posted: Mon Jul 23, 2007 9:45 am
Ride: EF XR8
Hi guys, I have an EF XR8.
I think I may have a cooling problem.
When my car is turned off, the temperature gauge needle is quite a bit below the bottom line. When I run the car, under normal driving conditions the needle barely goes into the normal area.
If I give the car a big go, it rises up to probably about 2/3
After a while mid rpm driving (such as on the freeway and giving it the gun around town), I get this light pop up of what looks like a water container, with a squiggly water line and a fan in it, it's in red.
The temperature gauge seems fine.
Sometimes I think I can smell it overheating but I cant be sure.
I pull over into the servo, undo the reservoir cap (which is always highly pressurised) and steam will come out, because of the pressure it usually will go all over the servo forecourt.
So I pour new water in (which is usually only about 1L) then drive off, the light has gone.
So all the symptoms point to an overheating problem, but the gauge seems fine, and I dont think I am giving the car a hard time.
I am thinking I might have a problem somewhere and the gauge isnt working properly?
What is the normal operation for the gauge?
Thanks for all your input
Wanted - boot floor and lining for sedan - cheap - Syd-Central Coast
Posted: Mon Jul 23, 2007 12:04 pm
Gallery: 5 images
Ride: 2021 Amarok V6
that light is the low coolant sensor. it might be a bit dodgy lol
Posted: Mon Jul 23, 2007 1:34 pm
Ride: 94 EF (OPT20), TF Cortina Ghia
try your dash in diagnostic mode and see what the temp says in there
"Look I found tape, I'm a mechanic now!!!" Mike Teutul
Posted: Mon Jul 23, 2007 2:46 pm
Ride: EF XR8
Hi mate, how do I go about doing that?
Posted: Mon Jul 23, 2007 11:13 pm
Gallery: 9 images
Ride: ED 5 Speed GLiXR
By the sounds of it, that light your seeing is the low level coolant light, these things have been known to get s**t stuck on hem and give faulty readings, or you may actually have low coolant level.
Check out the senor, if its f**k replace it, they arent that expensive to replace.
17" Tezza Steelies, King F**king lows, pedders sports ryders, 2.5" cat back exhaust, pacemaker extractors, T5 manual
Low, loud and Slow
Posted: Mon Jul 23, 2007 11:18 pm
Ride: BA XR8 & 06 4x4 Bravo
'04 BA XR8
Winter White, 5 Speed Manual, Sports Leather, Premium Sound, 2 1/2" Cat Back Exh - no rear Mufflers, Lowered SL/SSL, 20's, Underdrives, BF Typhoon Rear Spoiler, GT Steering Wheel, etc.
Posted: Thu Jul 26, 2007 10:52 am
Ride: EF XR8
Im thinking it could possibly be head gasket problem, any idea how much it would cost to replace these?
Posted: Thu Jul 26, 2007 11:42 am
Ride: F150 EL mont&2001 cobra
Check to see if the bleed hoses aren't blocked. they are the ones that run from the header tank to the top radiator hose and to the top of the radiator.
Smoken the hides in top gear
Posted: Fri Jul 27, 2007 11:43 am
Could also be a dodgy thermostat.
Posted: Fri Jul 27, 2007 3:59 pm
Ride: EL XR8, '08 Mondeo XR5t
Power: 205 rwkw
Could be a pin-hole in one of your hoses that's slowly leaking onto your motor, causing the smell. Or a slow leak from the timing cover gasket which was running down the motor causing the smell which happened to mine...
It doesn't sound like the sensor's cactus if you have to top the reservoir up. I'd put my money on a slow leak somewhere...
Posted: Fri Jul 27, 2007 4:09 pm
Gallery: 36 images
Ride: Fairlane
i was just about to say that scaffy, if you are putting 1L of water in when you go to the servo there must be a leak somewhere, which is what is causeing the smell (coolant dripping on engine) and also why your low coolant light is coming on (low coolant level)
Have a look around and see if you can see a leak anywhere out of the hoses, if not put some newspaper underneath the car over night and see if there is anything dripping down. if all else fails and you cant located it take it to the mechanics unless you are capable of doing some work yourself.
The Lane Lives.... Finally!!!!
Posted: Tue Jul 31, 2007 5:32 pm
Ride: EF XR8
Got a service done on the auto and the engine, doesnt seem to do it anymore, however, nothing was actually replaced in the cooling system.
A mystery?
Posted: Thu Aug 02, 2007 7:28 pm
Power: 205 rwkw
Give it time...
Hahaha... nah mate, hopefully it will bother you no more!
Posted: Fri Aug 03, 2007 12:26 am
Ride: ef xr8
Power: 229 rwkw
Just check that the thermos are coming on too. If not then it might be a relay, the relay box is behind the passenger headlight.
Because of Beer, Thirst is a Beautiful Thing!
'95 EF XR8 auto, Advance headers, 3" exhaust, Cobra manifold, BBK 75mm throttle body , 80MM Marauder MAF, Vortech V2 T Trim , 307 rwhp, 405 ft/lb 13.2 @ 105 MPH
Now N/A (permanent Lag) - AFR 165's, Comp XE270 cam, 1.6 RR - 269 rwhp 14.1 @ 102mph.
Posted: Tue Aug 07, 2007 3:11 pm
Ride: XHII V8S Ute
NT, Australia
I've had two of those bloody relays break this year....how coincidental.
Pacies & single 2.5'. New manifold to come soon...
It is currently Thu Jul 10, 2025 3:56 pm All times are UTC + 11 hours
