is it me or is something wrong?
Page 1 of 1 [ 12 posts ]
 Post subject: is it me or is something wrong?
Posted: Wed Oct 17, 2007 5:42 am
Ride: NC5.0 & 04 Ex!
Hey guys,
To give you a little background... A few months aqgo I became 2nd owner to a 1991 NC Fairlane Ghia 5.0 on Dual Feul. The car was STRICTLY a highway car owned by an old couple 20mins northeast of Lakes Enterance. They used to drive it to Melbourne and back ONLY on weekends to visit their daughter while during the week the car sat in the garage.
I picked it up in GREAT condition with 355k on the clock. Only mod is a 2.5inch cat-back exhaust.
Now... I took it to my dyno guy and did a pre-tune run. Out came a blistering 90.6rwkw. I was more than :shock:
So after 30 or so mins trying to convince myself the dyno must be broken, I started working on it top to bottom.
It's running a Impco 225 mixer with a L model convertor. Now, I removed the MAF and airbox and fitted a K&N straight onto the mixer.
I also found that I was only with 1.4L of oil! Flushed that, and replaced with 5L of Penrite HPR GAS 10W/40.
Changed the BPR5FS-15's to BPR6FS. On that note, 2 plugs were cracked!
Upgraded to TopGun 8.8mm leads. Got my gas guy to tune and time the motor.
2nd run out... 100.9rwkw
Now is it me? or does this seem quite low?
NO TV AND NO BEER MAKE HOMER GO SOMETHING SOMETHING...
Posted: Wed Oct 17, 2007 7:38 pm
does sound a little low, but the car does have 350,000 on the clock, so most of the motor is going to be a little loose. do a compression test and go from there.
Posted: Wed Oct 17, 2007 8:20 pm
Auto or manual?
I think the ballpark figure is 105- 120rwkw stockish so motor could be a little bit lazy. Or it could be any number of serviceable parts that affect tune.
Posted: Wed Oct 17, 2007 9:04 pm
Site Admin
Ride: AUII V8 LTD
Power: 270 rwkw
Sounds pretty spot on for a high mileage, auto, LPG, stock 5.0 - give or take a few KW for dyno variances.
Posted: Wed Oct 17, 2007 9:10 pm
Gallery: 9 images
Ride: EF / TERRITORY
100rwkw is preety low for 5.0L fairlane mate, considering Km`s are high but as you said mostly highway.
Posted: Wed Oct 17, 2007 10:29 pm
Ride: AU XR8
Seems prett decent to me for a stock E-Series windsor with 350,000k's, and on LPG...
Posted: Thu Oct 18, 2007 12:57 am
EFI Guru
Gallery: 28 images
Removing the MAF means the EEC will go to MAF failure mode. What this means incorrect or no load calculation and therefore incorrect or no spark advance. No spark advance means no power.
Posted: Thu Oct 18, 2007 2:20 pm
i was told don't need the MAF if i'm to run the car on LPG... do you guys think this is corect or is someone blowing smoke up my a$$?
ultimatly, i'd like to run the car on straight gas.
regarding power, first thing is first... my cousin is sending his old GT40 upper and lower intake manifold off one of his mustang from the USA (it's only costing my $50 and thats just the postage)
exhaust wise, ive been quoted $1850 for PH4000's, 2.5inch metal cats and a twin 2.25inch system with mufflers.
Posted: Thu Oct 18, 2007 5:01 pm
EFI Guru
Gallery: 28 images
What did I just say?
Posted: Thu Oct 18, 2007 5:23 pm
Power: 274 rwkw
You need the MAF. END OF STORY. As Pete has said, no MAF means base timing and no advance, which means no power.
Brett
Member#1131
Posted: Thu Oct 18, 2007 6:00 pm
thanks guys. putting it back on later this afternoon.
also, do you guys think at the km's that i'm at, would it be worth it upgrading heads and cam while i'd be in the process of upgrading the intake?
Posted: Fri Oct 19, 2007 7:14 pm
Power: 113 rwkw
Leave it as is till it starts blowing smoke, and wile your at it save your money for when it comes time to rebuild it.
BANNED
It is currently Sun Jul 13, 2025 11:56 pm All times are UTC + 11 hours
