[b]91 nc 5.0l map sensor[/b]
Page 1 of 1 [ 9 posts ]
 Post subject: [b]91 nc 5.0l map sensor[/b]
Posted: Sat Dec 06, 2008 6:22 pm
Ride: el falcon gli
hi guys was wanting to know where i would find the vacuum line for map sensor on this 5.0l i have acquired 91 nc runs very rough and would like to know if anyone knows where map sensor vacuum comes from. :)
Posted: Sat Dec 06, 2008 7:33 pm
Ride: AU1 XR8
V8's run a maf meter that is attached to the air box.
It has two little heat probes in it DONT TOUCH THEM.
You can clean them with electrical cleaner that leaves no residue.
Check egr valve isnt stuck open allowing exhaust gases in at idle.
Posted: Sat Dec 06, 2008 9:00 pm
Gallery: 15 images
Ride: BA Ford Fairlane V8
Early EBs and NCs also run a MAP. I'd imagine that the vacuum line would run from under the upper inlet which can be a bit hard to see what your reaching for. Also, do what RAPTOR_XR8 says, which will also do lots for your motor.
Interested in a fair go for the {DESCRIPTION} area of NSW?
Posted: Sun Dec 07, 2008 12:43 am
Power: 482 rwkw
Its actually a bap as it reads barometric pressure..
Its vented to atmo...
Same as 6 cyl map sensor though..
As in ZOOM 126 edition
Posted: Sun Dec 07, 2008 12:45 am
Ride: ED EF and AU V8s
correct,
so no vaccum line is used
i always wondered if you could use these to convert back to map only??
Too many cars atm
ED sprint
EF Fairmont V8
AU ghia V8
Posted: Sun Dec 07, 2008 9:56 am
Ride: AU1 XR8
So is there any good reason as to why ford used it then got rid of them.
Also without it plugged in would it effect the motor/tune.
Posted: Sun Dec 07, 2008 12:05 pm
not realy sure why ford used it, think it was a new system for the first of there SEFI motors using a MAF, proberly needed as many sensors as poisable to get the fuelmixtures/timing corect
maybe lol
Too many cars atm
ED sprint
EF Fairmont V8
AU ghia V8
Posted: Mon Dec 08, 2008 3:12 pm
EFI Guru
Gallery: 28 images
They found that there was enough air pressure compensation via ACT and MAF so they heave-ho'd the BAP sensor.
Posted: Mon Dec 08, 2008 7:42 pm
Ride: el falcon gli
thanks everyone who replied i found this information very helpful indeed.
It is currently Sun Jul 13, 2025 9:48 pm All times are UTC + 11 hours
