kcshep |
If i have around 2Gs to do a head change on my 302 windsor and i have a 302 clevo at home or to go alloy ones can anyone help me.
EBXR8380 |
Holley, Trick Flow; Edelbrock, Dart are all in your price range.. AFR's which are CNC machined are more expensive...
schnoods |
AFR 165's are around $2300-2500. I'd be looking at them if you can stretch the budget.
XH5LWEPN |
{USERNAME} wrote: AFR 165's are around $2300-2500. I'd be looking at them if you can stretch the budget.
What he said ^^^^^^^Cant go wrong there ![]()
_________________ STREETBUILT RACING |
Scaffy |
For the AFR 165s -
If you're patient and want to try bringing them in from the states for yourself, try these guys or do a search for online stores in the U.S. http://treperformance.com/i-521-afr-165 ... heads.html You'd easily have them to your door for $2000. For the Trick Flow gear, check out the Summit store, www.summitracing.com
millard455 |
{USERNAME} wrote: For the AFR 165s -
If you're patient and want to try bringing them in from the states for yourself, try these guys or do a search for online stores in the U.S. http://treperformance.com/i-521-afr-165 ... heads.html You'd easily have them to your door for $2000. For the Trick Flow gear, check out the Summit store, www.summitracing.com thats the way scaffy, always look to the u.s. first for stuff like this, can save yourself heaps of coin. if you have $2000 to spend on heads id jump on thoes afr's, works out to be about $1500au plus postage. gota love getting 91cents us for our au dollar ![]()
_________________ EL XR8 SERIES 2, 5SPD, HOT CHILLI RED, 200 ODD RWKW OF V8 FUN AND GAMES |
Users browsing this forum: Google Adsense [Bot] and 24 guests |
