Stevo |
Ok, EL TPS (Dual ones, for gearbox too yeah).
The holes dont line up with the AU TB. How do i go about getting this to fit? Steve |
XH5LWEPN |
Elongate the holes outwards. You will also need to elongate them to the sides too to get correct voltage.
_________________ STREETBUILT RACING |
Stevo |
Yeah thought i might have to do that.
Was tempted to just drill larger self tappers in heh |
prydey |
you will need new bolts as well as the holes in the au t/b are a larger hole and au bolts are too short. they are a fine thread. i couldn't find anything similar from a hardware shop. will need to go to coventry's or whatever you have where you are.
the beauty of me running aftermarket ecu is not having to worry about tps voltages. just calibrate them through the ecu.
_________________ eb v8: low loud and fast. just how a v8 should be. i guess the big question is, is it fast enough... |
Users browsing this forum: No registered users and 20 guests |
