Air intake with larger MAF?
Page 1 of 1 [ 5 posts ]
 Post subject: Air intake with larger MAF?
Posted: Sat Apr 05, 2008 1:25 pm
Ride: Gli
I've got myself a little problem. I have a 65mm AU throttle body and a 80mm Cobra MAF with a 3 inch(76mm) stainless air intake tube. Now I have been able to join the intake pipe to the throttle body with silicone joiners no worries but haven't been able to find a joiner big enough to fit around my MAF (which measures nearly 90mm on the outside) Any ideas on how I can get around this or is there anyone out there that has an 80mm or larger MAF and has a solution.
Cheers, Kris.
Posted: Sat Apr 05, 2008 2:36 pm
i think autobarn have got a few different reducers at northland ,just brought a 90mm to 75mm
Posted: Sat Apr 05, 2008 3:38 pm
Ride: Gli
ah i see, yer i tried autobarn in melton which is where I'm from but they got stuff all.
Posted: Sun Apr 06, 2008 8:43 am
[quote="ELXR6lookalike"]ah i see, yer i tried autobarn in melton which is where I'm from but they got stuff all.[/quote]
try a truck spares, they will have something. unfortunitly there parts are designed for 1000s of hours use and may cost a bit more than usual but they usually have 3' gear and bigger.
Posted: Sun Apr 06, 2008 12:16 pm
Ride: Gli
Yer i already tried the truck parts idea (old man is a driver). there are alot of things that nearly fit but not quite. I've ordered a reducer silicon hose from a rubber specialist down here so hopefully it will do the trick.
It is currently Mon May 19, 2025 1:56 am All times are UTC + 11 hours
