AU I,II,III V8 DIFFERENCES
 Post subject: AU I,II,III V8 DIFFERENCES
Posted: Thu Apr 03, 2008 11:45 pm
AU 1 V8
Has stock .440 lift cam, steel rockers and E7 heads
AU 1 XR8
Has all of the above only GT40 heads added
AU 2 XR8
Has .458 lift cam with 1.6 rockers and GT40 heads
AU 3 xr8
has .450 lift cam with 1.7 rockers and GT40P heads that have been ported and given bigger valves.
Yella terra sell good stuff but when Matt showed me his supposedly GT40P heads he had for sale (remanufactured) I cringed :x . 1 They were only gt40's and 2 they still had standard valves. Buyers beware I say.
Posted: Fri Apr 04, 2008 12:20 am
Ride: ef xr8
Power: 229 rwkw
Here ya go.
Because of Beer, Thirst is a Beautiful Thing!
'95 EF XR8 auto, Advance headers, 3" exhaust, Cobra manifold, BBK 75mm throttle body , 80MM Marauder MAF, Vortech V2 T Trim , 307 rwhp, 405 ft/lb 13.2 @ 105 MPH
Now N/A (permanent Lag) - AFR 165's, Comp XE270 cam, 1.6 RR - 269 rwhp 14.1 @ 102mph.
Posted: Fri Apr 04, 2008 7:22 am
dont know where you got that info t2te50 all au,s have gt40p,s apart from the period where the 220 had alloys ???
interesting in that chart they state the 200kw as having 1.7 rollers?? amazing how these different manuals and tech sheets have conflicting information
Posted: Fri Apr 04, 2008 10:14 am
Ride: AU XR8
t2te50, you never cease to crack me up. Where do you get your information from dude?
This thread should just be deleted rather than waste time to correct all the misinformation here...
Posted: Fri Apr 04, 2008 11:09 am
Ride: BF XR6, BF XT Wagon
Power: 197 rwkw
AU 1 V8
Has stock .440 lift cam, steel rockers and GT40P heads
AU 1 XR8
Has all of the above only GT40P heads added
AU 2 XR8
Has .458 lift cam with 1.6 rockers and GT40P heads
That is the correct information there.
Posted: Fri Apr 04, 2008 6:50 pm
EFI Guru
Gallery: 28 images
Can someone show me a photo of their stock, untouched Y303 alloy headed AU? I've never seen anything but 40p's on any AU no matter what type it is. Even an AU 1 V8 ute(not an XR8) had 40p's not E7's as some have stated they have.
Pete.
Posted: Fri Apr 04, 2008 6:54 pm
Gallery: 16 images
Ride: F350
Pete.
Ally Y303 heads came on S1 TS/TL50 only, nothing else, that was called the synergy 5000.
 Post subject: Re: AU I,II,III V8 DIFFERENCES
Posted: Sat Apr 05, 2008 10:03 am
Gallery: 25 images
Ride: 93 Maverick LWB/S2 LWB Delica
Power: 75 rwkw
AU 1 V8
AU 1 XR8
AU 2 XR8
AU 3 xr8
Please don't quote way off the mark facts, all stock AU 5.0L's came with GT40P heads including utes, high series etc, considering we started running Explorer engines with AU.
Read it from the horses mouth.
http://www.fpv.com.au/theheritage/falco ... 8-220.aspx
Alloy head basic info from the horses mouth.
http://www.fpv.com.au/theheritage/falco ... 0ts50.aspx
Due to your other misinformation I can only guess you were shown the stock GT40P heads they have for sale, they could have been GT40 heads but unless they imported them the GT40 heads are uncommon in Australia, I am pretty sure the only "Aussie" cars to get them was EB GT, ED Sprint and EL GT, none of these cars were sold in high volume.
93 Ford Maverick LWB automatic petrol guzzler (gets stuck where Deli doesn't, big pumpkins :evil:)
97 S2 Mitsubishi Delica LWB (off the road getting v8 transplant)
Posted: Sat Apr 05, 2008 11:47 am
Ride: T1 TE50 P01
Pete.
As mentioned, they only came on the T1 & T2 TS50/TL50... and then only on certain numbers.
There is a bloke on AFF with a black T2 running factory alloy heads.
TE50 T1 P01
Posted: Sat Apr 05, 2008 12:17 pm
EFI Guru
Gallery: 28 images
Pete.
Aha. Well that means that'd be the best engine to do because the Y heads have the most porting potential.
Posted: Sat Apr 05, 2008 2:22 pm
Ride: AU S2 XR8
where do u find the markings that tell u what they r? or can u just tell?
mmmmmmmmmmm 220 manual goodness!
Posted: Sat Apr 05, 2008 8:44 pm
Power: 174 rwkw
gt40p's have gtp stamped in them below the no.1 or 8 spark plug.
they also have 4 vertical casting marks down the front of them but they'll be obscured by all the ancillaries.
spark plug comes out a lot squarer than the e7's.
i think if you remove the rocker covers they also have gt40p stamped somewhere in there.
Posted: Tue Apr 15, 2008 5:46 pm
Ride: EL GT - T2 TS50
I have a T2 with Alloy heads - they have SVO on the back of them, I don't know if they are better from the factory, has 140k on it and the valve guides are not happy
Posted: Tue Apr 15, 2008 9:18 pm
Ride: 1993 EB XR8
A mate of mine has a Sillouette (sp) T2 TS50 with Alloy heads on it
Posted: Wed Apr 16, 2008 10:52 pm
Gallery: 15 images
Ride: BA Ford Fairlane V8
Also the non XR8 spec V8s in AU1s have 19lb injectors which suprised me.
Interested in a fair go for the {DESCRIPTION} area of NSW?
It is currently Sun May 18, 2025 8:52 pm All times are UTC + 11 hours
