XFWAGON |
Scored myself an 2003 AU upper and lower intake (explorer) with the injector rail, injectors, loom, hoses and ECU for $400, What ya reckon?? Will the ECU plug into my DC? or will i have to do a bit of modding, im pretty sure they used the EEC V which is on the EL2's so it should plug in? But i'm prob' wrong.
What else do i need to do to fit these goodies?
One Drone |
Intake itself is pretty much bolt off bolt on. ECU won't work for many many reasons. Coil pack for start? Otherwise good value mate. Good find.
3x-puursui7 |
woulda been an even better score if u got the blue top injectors but meh good deal. not sure bout the harness's though.
_________________ mmmmmmmmmmm 220 manual goodness! |
XFWAGON |
What did they blue ones come off? The reckons it come off a 2003 XR8, but didnt the 2003 xr8's have the blue 24Ib injectors instead of these orange 19's? Would the ECU be any better than the current EEC IV even if i got all the right bits?
One Drone |
Waste of time. You really want to play with the ECU? Get tunerpro, go to http://www.moates.net/ get some good gear to tune your car (on the fly if you want), get a decent datalogger and do it yourself. Warning: Lots of learning involved.
PC EB |
19lb injectors were only on the series 1 175kw engine.
XH5LWEPN |
Bout the only thing of use to you there is the Explorer upper and lower and the 65mm T/B.
The rest is pretty much useless to you unless you want to run coilpacks and change to EV6 type injectors.
_________________ STREETBUILT RACING |
green car |
I had a stock 175 kw au v8 and the injectors were blue
_________________ 165 Killer Wasps all packaged in a green kmart car, almost an explorer in a way... |
banarcus |
{USERNAME} wrote: I had a stock 175 kw au v8 and the injectors were blue
Yes very true, I've seen AU stock V8s with both blue and orange injectors. |
3x-puursui7 |
yes and also some 5L fairmonts and stuff had them, i think it was luck of the draw on the S1's wether u got 19 or 24's.
green car |
Are the blue ones 24?
Pretty sure my eb ones are orange.
XH5LWEPN |
{USERNAME} wrote: Are the blue ones 24?
Pretty sure my eb ones are orange. Yep the blue ones are 24's. However EV6 type 42's are blue aswell but lighter. Yeah your EB should have orange EV1 type.
XH5LWEPN |
*Double Post*
XFWAGON |
How easy is it and what do i need to polish the manifold up? How easy is it to install coil packs
banarcus |
Plenty of elbow grease and then some. Lots of work but the end result is worth it.
I used a small roller with sandpaper to get rid of the casting sand finish and then the old wet 'n' dry until very smooth. I bought some Josco wheels with their soap bars to polish it up. |
