BlownNc |
Age: 42 Posts: 451 Joined: 5th Nov 2004 Ride: 5lt Turbo NC, TE V6 Gemini Location: Castlemaine |
Ok, ive just dropped my v8 back into my NC but had the dizzy out and am trying to do the timing. Car is running rough like its running on 4 cylinders... anyway. Went to put the car into self test with the two pins (top and bottom left) and it did nothing...made no difference to idle. Now, is there a way to do timing without putting it into self test? I understand that it should be 30deg when in self test, someone told me 8deg without self test, is that right?
banarcus |
30* +/- 2* whilst in self test mode. Have you got the dizzy in correctly ie, its not a tooth out? I set my timing by ear without putting it in self test mode after I did my cam. Couldn't use the timing light.
BlownNc |
Ok, but any idea why i can't get it into self test?
Andrew J |
Ive also got this problem, what are we doing wrong? The revs dont pick up at all, it barely idles!
XR9UTE |
When you say it does nothing have you got a timing light on it and have you done this within two minutes of shorting the pins?
Andrew J |
Just an update on this. Turns out it is going into self test mode, it just wont raise the idle because the ISC has an issue somewhere
One Drone |
Have someone hold it at 1500rpm, same thing.
Users browsing this forum: No registered users and 50 guests |
