blacksabbath189 |
I'm chasing an edelbrock RPM or RPM2 upper to bolt to a 351 lower.
Would summit be the cheapest to buy through in the states? Or possibly someone has a upper kicking around in the shed by some shear miracle! cheers yawl
_________________ Slavery, gets s**t done! |
XR9UTE |
blacksabbath189 wrote: I'm chasing an edelbrock RPM or RPM2 upper to bolt to a 351 lower. Would summit be the cheapest to buy through in the states? Or possibly someone has a upper kicking around in the shed by some shear miracle! cheers yawl Which 351 lower have you got?...not all have the extra bolt pattern for the RPM upper and the RPM2 upper will not fit. |
blacksabbath189 |
I have recently purchased a Edelbrock 351w lower off a fordmods member. Haven't recieved item yet, so can't give part no's.
TerroristGHIA |
Part No is 3880. My RPM11 fitted as did my NOS Plate.
Brett
Scaffy |
The way the $ is at the moment, the only way you'll get anything cheaper than Summit is if someone local is selling a used one, and even then, with what they paid for it, they may want more than what you can get a new one for.
