V8/I6 engine mounts: the same?
Page 1 of 1 [ 10 posts ]
 Post subject: V8/I6 engine mounts: the same?
Posted: Mon Feb 16, 2009 7:30 pm
Ride: EF Ghia 5.0
I've been advised by another member that the EF/EL V8 and I6 engine mounts are the same. I'm assuming that there would be some sort of adaptor block required for either the 6 or 8.
Can anyone 100% confirm this? I just want to be sure before I spend the money. The cheapest V8 mounts I can get are $160 each, but if the I6 ones will do the trick and are cheaper, then it's a bonus. :)
Are they both hydraulic mounts in the EF/EL series?
Thanks, Mike
EF Ghia 5.0 - XR8 in a tuxedo....classy, low and loud
Bordeaux Purple, Tickford kit, slammed, 18" BA XR8's, EL Ghia chrome, full leather, Pioneer audio, C&C, ABS, LSD, Crane cam, GT40P heads, high flow cats, Genie extractors, lots of woodgrain, chrome and interior lights!
 Post subject: Re: V8/I6 engine mounts: the same?
Posted: Tue Feb 17, 2009 12:10 pm
Ride: 93 ED sedan
Power: 161 rwkw
They are not the same. Very similar to the old Clevo mounts but not quite the same there either.
http://youtu.be/jJTh9F3Vgg0
Posted: Tue Feb 17, 2009 2:26 pm
EFI Guru
Gallery: 28 images
4.0L mounts are the same hydraulic construction as 5.0 but the mounting portion is different.
You must be thinking of some other mount cjh they are nothing like early small block mounts.
Posted: Tue Feb 17, 2009 3:08 pm
the ones that are diffrent are the I6 and V8 mounths for EB-ED, the V8 ones for them are BIG
Posted: Wed Feb 18, 2009 7:46 pm
Ride: XR6 Turbo, EF 5.0L V8 Turbo
pretty sure only 1 is different on ef/el
i think it was the l/h one when i did the conversion.... maybe lol.
EF V8T 11.54 @118mph
Posted: Thu Feb 19, 2009 1:24 pm
Ride: 93 ED sedan
Power: 161 rwkw
I was meaning the bolt pattern of where it attaches to the block, that style of the upper steel part of the mount.
Posted: Thu Feb 19, 2009 2:01 pm
EFI Guru
Gallery: 28 images
All smallblocks have the same bolt pattern on the block.
Posted: Fri Feb 20, 2009 1:21 am
Ride: EF Ghia 5.0
I was trying to determine whether the actual hydraulic mount was the same, but had different adaptors bolted to it to mount either the 6 or 8.
Lots of opinions, but it still isn't really clear. Just trying to avoid spending $300 on V8 mount when the I6 ones are the same and get caught out. I almost did that with my TFI module: the (half as expensive) I6 one runs my Windsor quite happily! 8-)
Cheers, Mike
Posted: Fri Feb 20, 2009 10:14 am
EFI Guru
Gallery: 28 images
It wasn't my opinion...it's what i found when looking at both types of mounts.
Posted: Fri Feb 20, 2009 10:50 am
Ride: EL XR8
Cheers, Mike
I have replaced my engine mounts twice now in my EL XR8. The first time I used some after market ones because they were like $100 bucks cheaper each. But they lasted about 2 weeks before they fell too pieces! Ended up buying genuine ones from ford and haven't had a drama since. Though unfortunately they are quite expensive. In my experience I would just get them as it may save you another failure down the track!
It is currently Wed Jul 09, 2025 11:49 pm All times are UTC + 11 hours
