MAF Clean
Page 1 of 2 [ 20 posts ] Go to page 1, 2  Next
 Post subject: MAF Clean
Posted: Sun Mar 01, 2009 2:16 am
Site Admin
Ride: AUII V8 LTD
Power: 270 rwkw
Well last week my car started mising, backfiring and running like a piece of crap. I finally narrowed it down to the MAF, since the car ran great with the MAF unplugged. I figured it was shagged and started shopping for a replacement. Then the idea came about that maybe it needs to be cleaned
Sure enough, I purchased some electric contact cleaner, sprayed the hell out of it and now the car runs far better than it has in the 3 years I've owned it. I don't know why I didn't think of it earlier. I guess it will become part of my regular maintenance now.
Does anyone else service theirs regularly?
 Post subject: Re: MAF Clean
Posted: Sun Mar 01, 2009 12:02 pm
Ride: efxr8
Hi Waggin,
Did you do this with the sensor still in the body or take sensor out?
Would like to do this for mine too.
Cheers Andrew
Posted: Sun Mar 01, 2009 12:46 pm
Gallery: 28 images
Ride: NCII Fairlane + G220
Power: 143 rwkw
I clean everything I can think of in a service including the MAF. But I remove mine from the body and clean it with WD40 and a cotton bud.....2 minute job :)
Cheers,
Mick
E-Series Fairlane/LTD? forums/post746329.html#746329
Mick's Garage forums/viewtopic.php?t=65504
Posted: Mon Mar 02, 2009 11:14 am
Clean your maf more regularly if you have an oiled air cleaner(k and n etc) because it will draw the oil onto the maf.
165 Killer Wasps all packaged in a green kmart car, almost an explorer in a way...
Posted: Tue Mar 03, 2009 1:34 am
Site Admin
Ride: AUII V8 LTD
Power: 270 rwkw
Cheers,
Mick
Yeah, I cleaned mine by reming the electronics from the body. I was reading that both WD40 and cotton buds are both big no-no's for cleaning it though, hence buying the specialised electronic contact cleaner. It's a whopping $10 from Jaycar :)
Posted: Tue Mar 03, 2009 7:10 pm
Gallery: 28 images
Power: 143 rwkw
Cheers,
Mick
Ah well, hasn't given me any issues to date and have been doing it now for the last 18 months :o
Posted: Wed Mar 04, 2009 10:23 pm
Site Admin
Ride: AUII V8 LTD
Power: 270 rwkw
Cheers,
Mick
Handy to know, I wont bother replacing this can next time around. hehe
Posted: Mon Mar 09, 2009 9:02 am
Ride: BA Fairmont Ghia
Hi People - I have a BA Fairmont Ghia powered by a 5.4 litre 3 valve V8 engine. Does this motor have MAF sensors and if so where are they and how are they cleaned ?
Posted: Mon Mar 09, 2009 2:34 pm
EFI Guru
Gallery: 28 images
Nope BA's are all speed density...therefore no MAF.
Brake cleaner or non-oily contact cleaner are all that you need to clean the hotwire. Just squirt a bit through the sample tube. The hotwires should not be touched with anything.
Posted: Tue Mar 10, 2009 7:10 am
Thanks for the reply - I am not electronically or mechanically experienced and I have no idea of what you have replied, sorry. Could you please explain what you mean and where this tube is?
Posted: Tue Mar 10, 2009 12:15 pm
EFI Guru
Gallery: 28 images
You have no MAF.
The other bit was for cars that do.
Posted: Wed Nov 11, 2009 1:28 pm
Ride: FG MK2 XR6T
How do you remove the electronics from the TB? I tried last night and theres two screws holding it together. One is a Torx screw but the other doesn't seem to have head on it. I tried popping it off but didn't seem to work. Such a simple question but had me stumped for 20 minutes before i gave up.
BTW sorry about the thread mine. Was the most relevant when i used the search function.
Now......
Feb 2012 FG MK2 XR6 Turbo
- Manual
- Luxury Pack
Posted: Wed Nov 11, 2009 8:11 pm
I used to use Contact Cleaner on mine too and a clean MAF is a noticeable difference in fuel consumption and performance.
5.6L of carbon footprint.
Posted: Wed Nov 11, 2009 9:44 pm
EFI Guru
Gallery: 28 images
And, as I said before, just squirt contact cleaner/brake cleaner through the sample tube...No need to remove the electronics.
Those screws are called Security Torx.
Users browsing this forum: Google Adsense [Bot] and 11 guests
It is currently Mon May 19, 2025 11:43 pm All times are UTC + 11 hours
