A nicely shredded serpentine belt
 Post subject: A nicely shredded serpentine belt
Posted: Wed Mar 03, 2010 8:20 pm
Nailed the throttle on a freeway entrance ramp and the serpentine belt shredded itself. :P
Just wanted to check, what are the idler / tensioner pulleys generally worth if I find one of them rooted?
5.6L of carbon footprint.
 Post subject: Re: A nicely shredded serpentine belt
Posted: Wed Mar 03, 2010 9:02 pm
Power: 482 rwkw
Yep it happens.. How old is it ??
Check alignment...
As in ZOOM 126 edition
Posted: Wed Mar 03, 2010 9:06 pm
I think the odo is about 160K and the pulleys are the original ones.
I'm curious if genuine or aftermarket versions differ from eachother in terms of quality.
I'm also almost afraid to ask what Fraud will quote me.
Posted: Wed Mar 03, 2010 9:29 pm
Power: 274 rwkw
I picked one up for mine from Repco, was about 60 from memory, been a while. It was aftermarket and was steel with a bearing cage, the stock ones are plastic.
Brett
Member#1131
Posted: Thu Mar 04, 2010 6:51 am
Fordmods Addict
Gallery: 13 images
Power: 237 rwkw
idler looks okay, hard to see tensioner??
hope its idler, tensioner pulley is non-replacable, you've gotta get a new tensioner.
let me know how much they cost, i still need one :lol:
BF MKII F6 Tornado - 237rwkw
Posted: Thu Mar 04, 2010 1:38 pm
Just put new bearings in the pullys, will save you atleast half.
1993 ED XR6 5speed Polynesian Green. Project car.
1998 EL XR8 Auto Hot Chilli Red. New daily and project
Posted: Thu Mar 04, 2010 1:42 pm
NSW Cruise Moderator
Gallery: 12 images
Ride: TE50
very nice effort that one. looks like it has skipped across and chewed itself out on the way, not helpful I know.
I have a car.
Posted: Thu Mar 04, 2010 2:11 pm
Mr Todd, when I get a freeway entrance ramp in my sights I unleash the hamsters with utmost joy. :lol:
In this case I could not only feel the engine go blat but could hear it too and when I checked the dash lights, the voltage gauge light was on and the voltage needle was going down so I figured out exactly what was wrong in no time. :o
Anyhow I have a bike so getting around till I sort out the belt is no problem and it's cheaper on fuel than the stroker.
Posted: Thu Mar 04, 2010 2:44 pm
Ride: 1995 EF Fairmont
When I did my belt I felt my steering go a bit harder.Tensioner and Harmonic balencer for me.Can remember how much the tensioner was though.
I have not failed.I've just found 10,000 ways that won't work - Thomas Edison
Posted: Thu Mar 04, 2010 3:08 pm
Gallery: 20 images
Ride: XH Ute / AU3 V8 Wagon
Both pulleys are available aftermarket, made by Powerbond, sold under there Nuline brand. Both pulleys made from steel, with new bearings fitted. I have used these on my I6, very well made parts. Not too dear, a good parts shop should be able to supply them for approx $30.00 each. The part numbers you need to ask for are EP017 (smooth pulley, you will need two of these) and EP018 (grooved pulley, 1 only reqd) Good luck. :D
XH Ute Thread {DESCRIPTION}
Posted: Thu Mar 04, 2010 5:11 pm
Ride: EF-XR8chaser
pull the plastic oneoff and replace it with a nuline-steel one,all pulleys are much cheaper and cast iron with new bearings.
R.I.P HANS HARTMAN
Posted: Thu Mar 04, 2010 6:39 pm
Fordmods Addict
Gallery: 13 images
Power: 237 rwkw
it's not as easy as 'pulling it off' though on the tensioner.
i've got one that i've machined the pulley off but never got around to fitting a new pulley too it, mainly because it was a second hand tensioner assembly of unknown condition.
Posted: Thu Mar 04, 2010 7:19 pm
So far, only the power steering pulley shaft has any float in it, but I think that's normal for that item.
Posted: Thu Mar 04, 2010 7:21 pm
Ride: EF-XR8chaser
I SPLIT MINE-drill and tap a m8-m10 hole down the middle to hold the new brg.,tensioner springs are ok,ask papa smurf for the price of a new one.
R.I.P HANS HARTMAN
Posted: Fri Mar 05, 2010 12:03 am
Here's the old one.. good for a laugh.
New belt is fitted now but the top idler pulley isn't 100% so I'll get a new steel one.
It is currently Thu Jul 10, 2025 9:05 am All times are UTC + 11 hours
