gunit18 |
got quoted $544 for the crane 2030 cam from Superplus in Hallam, Vic. Also $132 for retainers, $105 for springs and $125 for venier timing chain set. Is this reasonable?? Anywhere else in melb that could be cheaper?
thanks |
fairmontman |
Perhaps buying directly from Crow themselves may save you a few bucks
http://www.crowcams.com.au/catalogue.shtml
_________________ Two hands and one mouth. Now that's a drinnking problem! |
EDXR8 |
Shop around, you should be able to pick the cam up for under $400, The other part prices look okay though. Also do you know the brand of the timing chain set. Rollmaster's are amongst the best and their 12 keyway versions are around $100 usually. Don't know if they do crane, but give VPW a call, I find they are usually pretty cheap.
ef302 |
Seems pretty steep. Even Herrod quoted me only $700 to change the cam in my V8. nad we all know what their prices are like...
_________________ Have YOU driven a monster truck lately?? |
xr8ute |
I am going through this myself at the moment...
My Crane 2030 is unused but bought second hand for $250 From VPW I bought Crane 44308-1 valvespring kit $240, and Rollmaster timing chain set for $120. I also bought a valvespring shim kit for $30, so I can get the proper install height for each spring. You will most likely need to by longer pushrods. In theory, they would be 0.060" longer than stock (stock is 6.270" I think?), but you won't really know until the cam is in and you can measure it all up. I bought myself some adjustable roller rockers instead, LOL. |
gunit18 |
wats VPW website?? U think I should buy the springs and that at Superplus and buy the cam somewhere else?
cheers |
richie |
I just bought crane 2031 from Holley Parts Wholesalers in Perth Price was $323 plus express airfreight ex USA $50.
Richie.
_________________ 1993 ED F/mont 5.0L, Auto, Edelbrock RPM's, CompCam XE276HR, Crane Gold Race 1.7's, Edelbrock Performer, 75mm T/B, MAP, 42lb , GenIII coils, PH4000's , Twin 2.5", Thermos & underspeeds, 3.7 LSD, 2800 stall and MoTec M800, 372fwhp @ 5400rpm & 387 ft-lb @ 4400 rpm. |
gunit18 |
how'd u get in touch with them? wats their website?
gunit18 |
Just got priced $330 from Eagle auto spares in dandenong, so i will get it from them. Im getting retainers $132, springs $105 and vernier timing chain set $125 from superplus. Might get push rods later with rollers.
Do I need anything else? Wat parts are you guys using - Crane springs etc? |
EDXR8 |
Are you planning on installing it without roller rockers? I really think roller rockers are a must with any cam upgrade on the windsors. Also the crane springs aren't the best option IMO, they are still single springs and can cause harsh valvetrain harmonics. I would recommend some double row springs, they are generally nicer on the valvetrain, I use crow double row springs which cost about the same as the cranes. Part number for the springs are 7738 and retainers are 11700, I got them from VPW.
gunit18 |
what would be some good roller rockers? Yella Terra? Crane?
EDXR8 |
Yeah Yella Terra or Crane do some nice 1.6 rockers to match that cam. I use the Crane ones and find them very good.
gunit18 |
got quoted $574 for yella terra roller rockers non adjustable. Adjustable ones were $697. Which ones would be better suited? Or should i shop around for cheaper ones, crane maybe? anyone know crane roller rocker prices? what should i get first - underdrive pullies and maf or cam etc.
thanks for the help! |
EDXR8 |
I would just go with the non-adjustable ones, I have fitted a number of cams with non-adjustable rockers and never had a problem getting correct geometry and pre-load, plus the adjustable ones aren't suppose to fit under stock valve covers. Crane rockers should be a bit cheaper I think, I have used both the Yella Terra and Crane rockers on my engine and both seemed very good quality.
gunit18 |
thanks for the advice guys
