looking to pull more power with out goin broke.
 Post subject: looking to pull more power with out goin broke.
Posted: Mon May 10, 2010 8:11 pm
Ride: NC 5 Litre Fairlane
got an nc 5l an im looking for more power with out going broke.
just some ideas guy.
cheers..
 Post subject: Re: looking to pull more power with out goin broke.
Posted: Mon May 10, 2010 8:13 pm
Ride: EF-XR8chaser
DONT------------MONEY SAVED
R.I.P HANS HARTMAN
Posted: Mon May 10, 2010 8:14 pm
Sell the NC then bud, coz the wheezer is gonna cost ya.. :wink:
Put a nice sounding Exhaust and Extractors on it and Put it on Gas and keep it as a Econo-bus.
Pre 1998 5.0 Windsor + Power = $$$$$$$$$$$$$$$$
EF Ghia 5L V8
BAMk2 XR8 Velocity/Cobra 19's
Posted: Mon May 10, 2010 8:15 pm
NSW Cruise Moderator
Gallery: 12 images
Ride: TE50
cheers..
Decent set of heads, get rid of the E7's decent cam and get the thing to breeth with some extractors and exhaust. all can be done over time, start with what your budget allows for.
Plenty of guys here will be able to dirrect you down what suits what, ultimatly depends on what sort of budget you have and what sort of numbers you are hunting for.
I have a car.
Posted: Mon May 10, 2010 8:18 pm
well i was thinking insted of power just go for the cruiser look its already got extractors. so maybey just wheels an s**t like that make it look good. no of any one with a manual for one of theese?
Posted: Mon May 10, 2010 9:35 pm
Ride: EA Turbo
What is your budget?
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Resprayed|microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Wade turbo cam|Crow double valve springs|1.3mm MLS headgasket|C4 conversion|Built bottom end|10.6@125MPHi
Posted: Mon May 10, 2010 9:49 pm
Gallery: 17 images
Ride: 5.0lt NF /351 ZD Fairlane
i bought an AU111 Explorer intake with a Phenolic spacer to reduce intake temps, and a polished Ford Racing 70mm throttle body and matching EGR spacer with a 70mm MAF and a set of 24lb injectors to put on the NF, which possibly would've been good for 20kw but after realizing how much restriction is caused by my LPG set-up I've decided to stay stock and get my ZD Fairlane on the road.
NF Fairlane with 5.0 and 5 speed goodness!
XE Fairmont Ghia
Posted: Mon May 10, 2010 10:06 pm
Ride: EF XR8 347
Power: 232 rwkw
Cant get decent power without spending money. They go hand in hand. If you cheap it you will end up spending more in the end when cheap things break. Save, plan, spend once, smile because you were patient and thorough and did it properly... unlike {DESCRIPTION} guy ;)
Posted: Mon May 10, 2010 10:25 pm
Ride: EF-XR8chaser
NOOOOOOOOOOOOOOO NOT AGAIN
R.I.P HANS HARTMAN
Posted: Mon May 10, 2010 11:05 pm
yer my budget is not much at the moment but once i get some omney i was thinking about 4.500 5000 around there but obviously want to do it cheap. but yer i dont wat it to stuff up and do it right first time... i have been told get rid of the e7 heads and go au with au maf and t body to start which is good i guess...
Posted: Tue May 11, 2010 4:15 am
with 5 grand you can easily buy an au 2/3 xr8 engine and use that with plenty of change for other upgrades, auto, diff etc
Posted: Tue May 11, 2010 12:45 pm
yer well its just case of getting the money up and doin it lol. i can get s**t relativley cheep now. im thinkin just buy a smashed au v8 from down fowles
Posted: Thu May 13, 2010 11:56 am
Ride: FG MK2 XR6T
If you have 5k just go for a Raptor Supercharger Kit. Might cost you 6k inc labour and tune but should give you at the very least 180rwkw on a E7 headed windsor.
Easily able to return to stock for when you sell the car. Far easier to fit than f**k around with heads, intake e.t.c. Beautiful Supercharger sound and will put out more power than a N/A AU3 220kw motor anyway.
http://www.raptorsc.com.au/kits.php?id=46
Now......
Feb 2012 FG MK2 XR6 Turbo
- Manual
- Luxury Pack
Posted: Thu May 13, 2010 12:44 pm
^^ What he said about supercharger - on EB Series most likely best bang for buck.
Posted: Thu May 13, 2010 4:19 pm
Ride: EF XR8 347
Power: 232 rwkw
Good bang for buck, but on an older engine expect problems to come out along the track. It will be ongoing. Blowing a motor stresses a motor and brings out the hidden weaknesses.
It is currently Mon May 19, 2025 3:32 pm All times are UTC + 11 hours
