EL ecu into EB pre smartlock
Page 1 of 1 [ 10 posts ]
 Post subject: EL ecu into EB pre smartlock
Posted: Fri Jan 13, 2012 8:43 pm
Gallery: 9 images
Ride: 97 TICKFORD XR6 Manaul
hey guys
doing some work to my sisters EB falcon.
her trans and motor are on the edge of needing a replacement which i have a EF tickford motor and trans for all ready to go in.
what im asking is will a EL ecu run a 1993 EB pre smartlock with a EF motor tricked up to EL specs
eg dissy not coil packs.
as i want to put a tickford ecu in
what im planning to do is
shift kit the auto
300kpa fuel reg
tickford specs
and lsd the b**ch (she love that one)
cheers jk
MY BABIES
93 NC FAIRLANE GHIA 4LTR-{DESCRIPTION}
97 TICKFORD EL XR6 5SPD-{DESCRIPTION}
 Post subject: Re: EL ecu into EB pre smartlock
Posted: Fri Jan 13, 2012 8:47 pm
Ride: BF XR6,
will need a chip or similar to turn off smartlock otherwise it should be fine
BF XR6
Posted: Fri Jan 13, 2012 8:50 pm
Gallery: 9 images
cheers, so a J3 chip will do fine then
nothing else i should worry about
MY BABIES
Posted: Fri Jan 13, 2012 8:51 pm
Ride: BF XR6,
not to my knowledge, your putting the bbm in and wiring it up to work?
BF XR6
Posted: Fri Jan 13, 2012 8:52 pm
Gallery: 9 images
no, no bbm
MY BABIES
Posted: Fri Jan 13, 2012 8:54 pm
Ride: BF XR6,
well the ecu is set to change its fuel map for the bbm when the bbm changes its runners so that will give you a problem if you dont have one on there in full working order
BF XR6
Posted: Fri Jan 13, 2012 8:57 pm
Gallery: 9 images
mmmm ok so bbm it is then. will check the tec on wiring that up
but this ecu will do fine then
MY BABIES
Posted: Sat Jan 14, 2012 7:42 am
Ride: EF Fairmont
hey guys
shift kit the auto
300kpa fuel reg
tickford specs
cheers jk
Just fit a Smartlock bypass module or get a EB/ED XR6 ECU
Posted: Sat Jan 14, 2012 6:42 pm
Gallery: 9 images
will a EB/ED xr6 ecu run a EL motor with a bbm then
or are you saying if i run a EB/ED ecu i dont havr to worry about the bbm
MY BABIES
Posted: Sat Jan 14, 2012 7:51 pm
Ride: BF XR6,
depends which eb ecu you get, some are pre smart lock, if you run an eb/ed computer you wont need to worry about the bbm just fit the standard log one, in all honesty the computer wont do much at all just run the standard one
BF XR6
Users browsing this forum: Google Adsense [Bot] and 11 guests
It is currently Tue Jun 24, 2025 7:05 am All times are UTC + 11 hours
