Is this worth buying: Ef throttle body
Page 1 of 1 [ 6 posts ]
 Post subject: Is this worth buying: Ef throttle body
Posted: Thu Apr 26, 2012 9:22 pm
Ride: Ef Fairmont
Just want to know if this is worth the dosh guys, not too bright with throttle bodys sorry guys. Carbs I know, EFI.... Im learning
http://www.ebay.com.au/itm/FORD-EF-EL-P ... 519e969890
 Post subject: Re: Is this worth buying: Ef throttle body
Posted: Thu Apr 26, 2012 9:24 pm
Ride: BF XR6,
been told there is no gain using a bigger throttle body, unless you have a s**t of mods done
BF XR6
Posted: Thu Apr 26, 2012 9:42 pm
Ride: DL LTD
Like bry said it comes down to the mods you have done...what size is your manifold inlet?...if its smaller than the tb you would have to port match it at the very least...but unless you have the heads/cam/tune etc you would probably find you had less throttle response
Dont worry about the learning curve....I know what you mean...carbies seemed soooo easy lol
Lets just pretend I give a s**t and leave it at that.....
Posted: Thu Apr 26, 2012 9:43 pm
Ride: Ef Fairmont
Posted: Thu Apr 26, 2012 9:52 pm
Ride: 1996 EFII Gli OLympic Classic
Got one to go with the spare BBM I got (for free) :D
Put it on it's a negligible gain having said that If you've got a massive cam and extensive headwork etc then it'd probably come into its own.
Posted: Thu Apr 26, 2012 9:56 pm
Read this mate i just read through it myself.
It will answer your question a bit i think
Awakening the Aussie Ford Six - Part One
It in articles :)
It is currently Thu May 22, 2025 7:38 pm All times are UTC + 11 hours
