speed sensitive steering
 Post subject: speed sensitive steering
Posted: Tue May 01, 2012 12:43 am
Gallery: 9 images
Ride: el fairmont
Hi i have a 97 el fairmont .
Q. does it have speed sensitive steering or is it only the ghia ?
also a friend of mine has a el fairmont ghia & her sss is super easy all the time so at speed it is a bit sketchy ,is there a speed sensor for the rack that needs changing
 Post subject: Re: speed sensitive steering
Posted: Tue May 01, 2012 9:57 am
Gallery: 9 images
Ride: el fairmont
the steering is not getting firmer at speed on my friends el ghia ,i had a mazda 626 turbo with speed sensitive steer & it had the same problem at speed ,it was a sensor switch on the gearbox ,do the fairmont ghia's have a sensor ?
Posted: Tue May 01, 2012 11:12 am
The EL uses output from the ECU to control a variable valve at the steering rack.
It goes from maximum assistance at low speed, to minimum assistance at road speed. I don't know what the speeds are at which is changes though.
EL Fairmont Ghia - Manual - Supercharged
- {DESCRIPTION}
- {DESCRIPTION}
Posted: Tue May 01, 2012 1:11 pm
Gallery: 9 images
Ride: el fairmont
Also my el fairmont steer is quite stiff well not as easy as the ghia & not as easy as a ef fairmont i had ,do i need new rack ? it has new steer pump & all hoses new rack ends & tie rod ends new ball joints , any ideas?
cron
It is currently Sun May 25, 2025 3:20 am All times are UTC + 11 hours
