fuel filter issues need help
Page 1 of 1 [ 12 posts ]
 Post subject: fuel filter issues need help
Posted: Sun Sep 09, 2012 9:08 am
Ride: ba ford 03
hi i have ba 03 futura and trying to change fuel filter.the filter was in backwards(worked fine)(flow arrow pointed to rear) and the new z373(both filters are z373) is a different size so i was left with no choice but to just turn the old one around now it seems to be hunting abit is this due to a dirty filter or direction?(flow arrow pointed to front) should i turn it back.Cant find a filter that will fit any one else had this issue please help.10.4l/100km.I asked the team at supercheap and ford but no one has any idea. :?
 Post subject: Re: fuel filter issues need help
Posted: Sun Sep 09, 2012 9:18 am
Ride: Various
If the thread sizes are the same, bend the metal pipes a little to make it fit,
mm, unlikely.
Posted: Sun Sep 09, 2012 9:45 am
Ride: ba ford 03
the bracket it sits in is also larger any ideas the new one would just flop around in it
Posted: Sun Sep 09, 2012 10:44 am
Ride: EF-XR8chaser
replace it with the same brand,when you turned it around you put all the rubbish into the motor,it may clear or need work.
R.I.P HANS HARTMAN
Posted: Sun Sep 09, 2012 10:59 am
Im using that same gold coloured filter. Its shouldnt move much once the lines are tightened.
Posted: Sun Sep 09, 2012 3:17 pm
Ride: ba ford 03
both filters are ryco z373 ???why the difference
Posted: Sun Sep 09, 2012 3:22 pm
Ride: ba ford 03
also im getting 730ks to tank is this alright 10.4l/100km wat is everyone else getting??
Posted: Sun Sep 09, 2012 4:11 pm
That is awesome fuel economy. Do you drive like a granny ?
In all seriousness i would be happy with that.
Posted: Sun Sep 09, 2012 7:27 pm
Ride: EF-XR8chaser
the ryco one-try repco,the smaller no name replacement-supercheap,or old stock ryco still sold.
R.I.P HANS HARTMAN
Posted: Sun Sep 09, 2012 7:28 pm
Ride: EF-XR8chaser
R.I.P HANS HARTMAN
Posted: Mon Sep 10, 2012 8:43 am
Ride: ba ford 03
i agree not my smartest moment.thanx for all your help like stubbie cooler idea ill go with that.no granny driving always doing 100 wat i save in fuel i spend in oil and filters.the k and n air filter help with fuel economy.service every 5000ks and i have 250 000ks on the clock.i am going to run some injector cleaner and fit the new ryco z373 filter and hope this works for the rough idle
Posted: Mon Sep 10, 2012 12:59 pm
Power: 144 rwkw
might want to get your injectors cleaned...or just get a second pair from wreckers to see how that goes. No doubt the reversing of the filter has caused s**t to go through the system and most likely into the injector filter/basket or whatever it is called.
phongus = Post whore 2006
Users browsing this forum: No registered users and 19 guests
It is currently Mon May 26, 2025 4:34 am All times are UTC + 11 hours
