bondy99 |
Age: 66 Posts: 1128 Joined: 13th Sep 2010 Ride: Ford Falcon AU 2000 Series II Location: Crestmead |
G'day again.
I've been researching and googling for a scantool that will read and reset ECU, Airbags, Engine and Transmission. Next door neighbour tried to use a scantool for my car but could not connect to ECU. I was under the impression AUII is OBDII, however, it appears not and may well be OBDI. How does one tell the difference. I am attaching a photo of the OBD socket, perhaps somone on this forum who has an identical car and has successfully used a scantool onthis vehicle. Cheers
low_ryda |
I believe the AU used it's own version somewhat of a OBD1.5. There is a thread around this forum 'scantool fun' the last few posts discuss use of an elm scanner with au's.
*edit. just checked and it's in the b series forum so you might not have found it: {DESCRIPTION}
bondy99 |
low_ryda
Thanks mate, I'll check it out. I've checked many of similar topics but never quite covered the problem I have. Cheers |
rmack |
There is software called FORScan that works on the AUII with any ELM327 Scantool.
The best thing the software is free and wriiten for Fords/Mazdas Live data, Clear Codes http://forscan.org/ |
bondy99 |
Hello rmack,
Thanks for that. I'll definetly looked into this one. Cheers |
low_ryda |
That's the one I was referring to rmack. works for me.
bondy99 |
low_ryda
Thanks for the confirmation. |
bondy99 |
Hi Guys,
I was given this information from GLM Software about the ELM327 chip "The ELM327 chipped scan tool is capable of reading your DTCs, but the commands you send to read them are not OBDII commands, they are proprietary mode 22 commands" The ELM327 returns all results in hexadecimal format, therefore you would need to convert those values before they became human readable" Is this correct? If so, what did you use to covert this hexidecimal format into something that I can read without the gobligook. As I will be using the software called FORScan, do I need anything else apart from a laptop and the ELM327 ScanTool? Thanks |
low_ryda |
FORscan does the hard work mate.... the elm, a lap top and the car were the only things I used with minimal computer knowledge.
bondy99 |
low_ryda
Thanks mate, that's what I needed to know, too easy. I received my scatool today, just need to borrow a laptop and install FORscan software. Cheers |
schmichael |
hey guys,
any updates on this? i'm thinking of buying one of these http://www.ebay.com.au/sch/i.html?_odkw ... 7&_sacat=0 do you have any experience with any of these bluetooth models + FORscan?? |
