GeZza200 |
Gday,
I bought some AU injectors today to replace the ones which i think are dodgy in my EL, are these straight plug in because the actual EL injectors look quite different. I havn't had a good look at the plug but im hoping they will go straight in. The EL injectors are 18lbs The AU injectors are 20lbs Will let you know how i go, im hoping it will fix my flat spot but if it dosn't i know the injectors are better for future mods. Im sure someone else has done this, is there anything special i need to do before i put them in? should get some carby cleaner an give the ports a scrub? or dont worry about it. Cheers
_________________ EL Futura: CVE head, Wolf V500, ICE Ignition and Coil, 36lb injectors, Walbro 255lb, Paci comps, 3" exhaust, T5, Harrop Truetrac with 3.9s. Now with 198.9rwkw, (~185rwkw and 13.80 @99.1mph) with more power to come |
FAST-XR |
yep they are a direct fit, i put them in my el, all you have to do is grease the oring before you slip them in. you wont notice a difference in power, but you will feel a smoother delivery.
_________________ 07 BF MKII XR6T |
phongus |
{USERNAME} wrote: yep they are a direct fit, i put them in my el, all you have to do is grease the oring before you slip them in. you wont notice a difference in power, but you will feel a smoother delivery. +1 to that...straight fit and smoother ride ![]() I'd also suggest getting a new fuel filter if you can be bothered...will help keep the injectors cleaner initially. If you can really be bothered, clean the fuel rail and maybe check the fuel rail to see fit is dirty...saves you from getting old dirt stuck in the new injectors. phong =P~
GeZza200 |
ok thanks for that, I got a new fuel filter about 6 months ago so that should be ok. How do you clean the fuel rail and what with?
relaxed_diplomacy |
Don't you also need to fit an au fuel pressure regulator?
_________________ wrecking 9/97 EL fairmont sedan burgundy 6cyl auto 270k modBAintake |
GeZza200 |
I hope not
FAST-XR |
no you dont need it, just replace the injectors and drive!
fiftyone |
just throw them in. no other mods.
replaced my fuel pump and its improved the low down response a little. however didn't do anything for the hesitation and bad idle or low power. ![]()
Sommers NL |
heya
![]() I put 30,000kms AU injectors in my car (hopefully days!) will take out my 200,000kms+ injectors in, for the AU ones, Cos i got hold of a free AU BBM, with everyone on it, including injectors, I was going the back of the wreckers, and find that the, AU S3 Falcon, that only down 30,000kms ... Laticia .
_________________ BANNED!!!! |
Futuraclassic |
hey everyone im thinking my injectors on my au are beyond their use by date and was looking at new ones, how hard is it to remove them and replace? is there a doc on here smwhere on how to??
_________________ People hate the au series but i wouldnt have it any other way!!! |
TROYMAN |
{USERNAME} wrote: hey everyone im thinking my injectors on my au are beyond their use by date and was looking at new ones, how hard is it to remove them and replace? is there a doc on here smwhere on how to?? no need for new ones, just get them cleaned.. |
Esteven8 |
Just put an AU fuel rail, pressure reg and injectors into the wagon and..
![]() I'd recommend this quite straightforward mod to any EF/L owner. Well worth the $11.50 (cost of 1 injector) the nice girl at the local wreckers charged me for the whole lot ![]()
FORD-FirstOnRaceDay |
Hey guys sorry to resurrect an old thread but I am looking at upgrading the fuel injectors in my EF, I was wondering if the AU injectors are the best way to go? Or are there any better options? And what setup would go well, such as what fuel pump, fuel rail and pressure reg should I use? Thanks in advance!
SWC |
{USERNAME} wrote: Hey guys sorry to resurrect an old thread but I am looking at upgrading the fuel injectors in my EF, I was wondering if the AU injectors are the best way to go? Or are there any better options? And what setup would go well, such as what fuel pump, fuel rail and pressure reg should I use? Thanks in advance! ![]() For NA there is really no options other than the AU 20lb injectors. If you were to go any bigger, you would need to chip the ECU to control the injector and they would be scaled back to what the AU Injectors are, so no benefit to going any larger unless you are going boost. The AU injector will give you a better spray pattern, 4 holes v the 1 hole in the 19lb E series injector. There will be no performance increase other than you may feel a small amount of improved throttle response, you will notice a small improvement in economy. Stock fuel pump, stock fuel rail, stock pressure reg. AU std pressure reg was still only a 270kpa, XR6 300kpa and VCT 350kpa. |
Alright cheers for your help mate!
