EACRUISER |
Just thought i would ask if anyone out there is running a EMS Stinger in their falcons.
I just got my engine and transmission rebuilt ready for the turbo i have sitting on the shelf at home, and the performance shop installed an EMS Stinger to run the whole show. It has these options * Injector types eg, Multi-Point 1, Multi-Point 2 & Throttle Body * Anti-Lag, Drag and Rally * Selectable sensor applications eg Magnetic or Hall * Selectable triggers * Selectable No. Cylinders * Selectable Ignition types * Stage Injection * Boost Cut * Rev Limit (Rev Soft) * Rev Cut * On Board Map Sensor * Engine Status * Displays current status of engine. ie Water temperature in Deg C ( -20 to +235 ) Air temperature in Deg C ( -20 to +235 ) Manifold pressure in K.P.A ( -100 to + 155 ) Engine RPM ( 0 to 12500 ) Fuel pulse in milliseconds (mS) ( configurable ) Battery voltage in Volts ( 6.5 to 23 ) Throttle position in % opening ( 0 to 100 ) Ignition in Deg. advanced (Static to 51°) --Inputs-- *Built in manifold pressure sensor to measure engine load. *Barometric pressure compensation. (Autocompensation for different weather conditions and changes in altitude). *Internal battery voltage sensing and compensation. *Air temperature sensing (compensation to Fuel or Ignition) *Water temperature sensing (compensation to Fuel or Ignition) *Programmable for different Air/Water Sensors. *Selectable - Hall, magnetic or optical on trigger circuit. *Selectable - Hall, magnetic or optical on sync circuit. *Throttle position sensing --Outputs-- *Adjustable ignition timing ( 0 - 51 Deg. Advance in 0.2 Deg. increments). *Adjustable dwell control ( 0 - 5 mS). *4 Ignition outputs for sequential ignition timing. *4 injector drivers incorporating 4 to 1 current ratio for injector response and lower power consumption *2 Auxiliary outputs Each o/p has 12 options – eg, Boost control, thermo fans,NOS, Tacho, Warning lights, A/conditioning control,Water Methanol Inj., Shift light, Idle control, Cam control (Vtec), Fuel pump control with automatic safety cut out if engine stalls, and many more. *Data Logging to Laptop which was included as an optional feature DO YOU THINK THIS WILL BE SUITABLE FOR MY APPLICATION (CIRCUIT RACING, DRAG RACING and STREET CRUISING@Speed Limit) |
SVO XR6 |
spend a lil more and get the 8860
worth the extra dollars, youll save it in tuning time
Bert |
The stinger does not do real time tuning which can cost more in the end than the 8860 if you're paying someone to tune.
Spork |
also if you have a look it has very poor resolution in boost. Only 2 load sites.
Go for something more advanced if you want good drivability and more engine life. - see CPU comparison sticky.
EACRUISER |
Take a look at the EMS Website here is a comparison with the 8860 and the Stinger 3 - sorry should have said stinger 3 up in the first post. as that is what is in my car.
ECU Comparison {DESCRIPTION} |
EACRUISER |
ECU Comparison {DESCRIPTION} It has real time mapping and most of the other options that the 8860 has. |
Waggin |
8860 for sure.
A few critial points Drivers peak & hold 8 Vs 4 - You have a 6cyl, 4 injector outputs arent enough if you want to run sequential 3D tuning table RPM X Load sites (Maximum) 96 X 32 Vs 26 X 11 - Can never have too much resolution Fuel table RPM/Load sites are independent of Ignition table YES vs NO - Independant tables would be benificial
SVO XR6 |
^^^ thats the stinger your talking bout rite?
check the new auto tune software with the 8860, its to die for! I made a entire fuel and ign map, 80% correct and much more drivable then before ( and efficent ) in about 2-3 hrs of driving on the street. Easy and cost effictive I found a good EMS tuner in perth ( i thought there wasnt such a thing) with a dyno, so ill take it there after i have a bit more of a play and ill tell ya how it goes ![]()
