Dirty Injectors??
Page 1 of 1 [ 5 posts ]
 Post subject: Dirty Injectors??
Posted: Sat Jan 21, 2006 12:39 pm
Ride: EL XR6
Today I took the number one and two injectors off my car to have a look. On the bottom there was a build up of dirt, not on the nozzle itself but around the bottom area under the area of the o-ring. Does this mean that the injectors are dirty and need cleaning or is this normal to have some dirt in this area.
I pulled them off becuase the car is using to much fuel at the moment and it has a rough idle.
Posted: Sat Jan 21, 2006 1:02 pm
Ride: BA mk11 XR6T UTE ,v8 fairmont gh
mate i reccommend having your injectors cleaned, I had mine done and the throttle response has increased dramatically, it go rid of that lag when you floor it, I have the same rough idle, so the mechanic suggested the clean, still got the rough idle after clean, so I didnt have to pay for it, But it sure does make a difference when Im playing hard.
Posted: Sat Jan 21, 2006 4:46 pm
see a mechanic about having a carbon clean done.
that will clean the injectors and also clean all the carbon build up from the valves, pistons, chambers and ports
Posted: Sat Jan 21, 2006 4:51 pm
Ride: EA
cost me 120 to clean my injectors and get new o rings and the dude even re sprayed the injectors lol!
Ford Falcon EA Naturally Aspirated 4.0L i6
13.797 @ 157.16km/h (Limiter Bounce)
 Post subject: injectors
Posted: Sat Jan 21, 2006 6:50 pm
get them flow and spray pattern tested , ultrasonically cleaned new filter baskets, orings and spintle cap, then re tested get all the crap from inside of them
Users browsing this forum: Google Adsense [Bot] and 14 guests
It is currently Fri Jun 27, 2025 12:03 am All times are UTC + 11 hours
