KiwiDazza |
I have put a EL XR8 engine into my 67 Mustang...I have most of the wiring, the ECU and TCM however I do not have the BEM or ignition. Is there an easy way to send a signal directly to the ECU and completely by pass the problem of not having a BEM?
Or would it be easier to have a trip down to the wreckers and pull one out of another car and rewire that way? Any help would be greatly appreciated. If anyone does know the answer and doesn't want to post in a public forum I can supply an email address if that helps. |
data_mine |
You can get the Smartlock disabled in the ECU, with a chip.
There's also a ~$300 smartlock bypass unit, but I don't know if that fixes the ECU or the BEM (ie. you may still need a BEM). Or yeah, wire up the rest of the BEM and a smartlock ignition barrel/lock.
ebfairmont3.9 |
go to the auto parts for sale section on
{DESCRIPTION} i am selling my smartlock bypass unit. as my EB1 was written off and i didnt need it anymore.
_________________ 1994 ED Fairmont Champaign Gold - AU Series II Intech 4.0L - EL EFI - Thermo Fans - 4.11 LSD - Pacemaker 4480 Into Custom 3" Exhaust - Shift Kit |
Mhgill |
Do a search on "smartlock by-pass" theres a guy in WA on here who sell's 3 wire Smartlock bypass's for $150-.
Got one from him myself, works a treat. Earth, 12V and a signal wire that goes straight into the ECU at pin 4. 5 min install too easy. Cheapest and easiest you'll find. Very hard to wire up a BEM yourself.
_________________ EL Fairmont Ghia 5.0 |
ebfairmont3.9 |
i got the jim mock bypass advertised for 150 but ill do it for 120+ postage im in brisbane see above post...
i had it in my eb1 for about 2 months then it got written off.
Users browsing this forum: Google Adsense [Bot] and 14 guests |
