theblackone |
should i be worried if i see some green coolant around the gas mixer? i opened up the bonnet and got a bit of a shock. what is the problem?
_________________ SIGNATURE REMOVED - REFER TO FORUM GUIDELINES! |
MadMatt |
Mixers do leak coolant.
_________________ Member Number 8804 |
theblackone |
so nothing to worry about?
Disco Frank |
umm how much coolant?
and wear from? fromt eh seal or from were teh hose goes in/out? they are not supposed to leak
_________________ RIP SCOTT |
theblackone |
like a very thin layer around the edges where the gasket is.
twr7cx |
Means the gasket is ggone, orr going. Time for a new converter or rebuild kit for the old one.
Disco Frank |
{USERNAME} wrote: like a very thin layer around the edges where the gasket is.
yer liek twewafdr3q4 said u can fix it yourself if ya handy... ![]()
theblackone |
and if ur not handy.....
![]() also ... with this new rebate.. if i go for vapour injection... would i be able to get a rebate even though i already have a dual fuel set up?
Disco Frank |
{USERNAME} wrote: and if ur not handy.....
![]() also ... with this new rebate.. if i go for vapour injection... would i be able to get a rebate even though i already have a dual fuel set up? no no rebate asu have gas already you would need to take car to gas place and get them to remove convertor and look at it could be a new gasket is all that is needed or a whole new conveter
theblackone |
f**k f**k f**k just wat i need to hear
Disco Frank |
meh how bad is it?
is it leaking lots or just a bit?
theblackone |
u know when you have abottle of..say milk and you open it up and turn the lid and u see like a thin layer of milk on the lid...well thats how much
creeture3 |
If you are mildly dexterious, most converters are really easy to "recondition", just follow the instructions
Just ask your friendly gas person to get in for you a kit to suit your converter. Be warned, however, converter kits for converters like Landi cost a bomb.( $150+), whereas the converter cost about $700 The cost of a kit for an Aussi B2 is about $70. But it is cheaper than buying a new converter. ![]() |
