URGENT WOLF 3D V4 ECU QUESTION - PIN CODE SECURITY FEATURE!
Page 1 of 1 [ 11 posts ]
 Post subject: URGENT WOLF 3D V4 ECU QUESTION - PIN CODE SECURITY FEATURE!
Posted: Thu Apr 17, 2008 8:18 pm
Hi All,
Really hoping someone's able to urgently help. Appreciate any information anyone's able to offer!
My car's fitted with a Wolf ECU. This has a pin code security feature - basically you are only able to set the code once - to change it the ECU must be sent back to the manufacturer.
I was of the understanding that the pin code security had never been activated, and as I had someone break into the car last night, I thought I'd better set it up.
Unfortunately it looks like the feature has been activated by one of the previous owners, and I am now not able to start the car - as I do not know the code.
I know it's a long shot, but does anyone know any way around this?
Due to the nature of my question, I would appreciate if any advice could be taken to PM please.
Thanks,
Justin.
Posted: Mon Apr 21, 2008 5:39 pm
Ride: EL TURBO GHIA
Power: 372 rwkw
as far as i know you could try the obvious as i think you can keep puting in the numbers till ya hearts content ,looks like you might have to send it back ,or contact the person you bought the car off
HMMMM BOOST !!!
ED fairmont R.I.P
STREET FORDS FEATURE CAR ISSUE 42
Posted: Mon Apr 21, 2008 5:45 pm
Thanks mate, all sorted now! Took it back to Wolf - 30 seconds and $100 later it's cleared!
I did contact the 3 previous owners and all said that no pin had been set.
Posted: Mon Apr 21, 2008 6:14 pm
Ride: EL TURBO GHIA
Power: 372 rwkw
oh ,$100 thats a bit costly
HMMMM BOOST !!!
ED fairmont R.I.P
Posted: Mon Apr 21, 2008 7:58 pm
A little, but not much choice! I laughed when he came back with the job done - he literally took it out of my hands, walked into the back room, was there for maybe 20 seconds, and walked back in and said all done!
Posted: Tue Apr 22, 2008 12:08 am
Ride: EL TURBO GHIA
Power: 372 rwkw
yeah right ,must be something very simple on the unit jumping 2 pins or something
HMMMM BOOST !!!
ED fairmont R.I.P
Posted: Tue Apr 22, 2008 11:36 am
Too true! I commented on it, and his reply was that he had the program ready and waiting for me as I'd rang before I arrived.
Edit - Double post!
Edit - triple post!
Posted: Sat May 03, 2008 12:24 am
Ride: EL Fairmont Ghia V8 Turbo
Power: 303 rwkw
I've got the pin setup on my wolf, u can arm and disarm it if u know the pin, quite handy.
Also it the car can't be hotwired as it turn off any signal to the injectors etc
In the manual it says that to clear it it must be returned to the manufacturer and your only allowed to set the pin once
EL Fairmont Ghia V8 Turbo 303rwkw
Posted: Sat May 03, 2008 1:31 am
Yep, definitely a handy feature. I did read that section in the manual before I tried to set the pin, and I then contacted all previous owners, who all said that no pin had been set.
Once I activated the pin code feature, it asked for the pin number - Unfortunately someone HAD setup a pin code on it before I got to it!
It is currently Sun May 25, 2025 11:16 pm All times are UTC + 11 hours
