fiftyone |
hi guys, brought a set of falcon injectors off ebay >>> http://cgi.ebay.com.au/ws/eBayISAPI.dll ... :IT&ih=013
they are brand new, got them today. the model number is 0280156186 however i had a quick look at this and the number is 0280155844 http://cgi.ebay.com.au/FORD-AU-AU2-FUEL ... dZViewItem i will send the guy a message asking if its right but i only have 7 days to return. anyone know if the ones i got are ok?
phongus |
The AU injectors I have in front of me are 0250155844...
phong =P~
fiftyone |
MF!!
http://www.injectorsonline.com/ australian company there. i think this guy has stooged me dam it.
hans hartman |
{USERNAME} wrote: MF!! get back on ebay and ask the guy,and fix it up--its easy
hans hartman |
schnoods |
Stooged??
You bought a set of AU injectors for $120, yet injectors online sell em for $60 + GST EACH. Which means instead of paying $360 you payed a third of that. Yet the 2nd set on ebay is $297 for a set. The Part numbers dont match up but have you checked the specs anyways? It might be one of those odd occurences where you can have a couple of different part numbers for the same product. I have bought a set of injectors off ebay and have saved a few hundred for a set. I bought a set of 8 new injectors (bosch fms 42 lb green top) for $420, injectors online want $90 + GST each making a grand total of $792. ![]()
phongus |
I just pulled my old EL injectors off my BBM and part number is 0280150736
phong =P~
phongus |
Found some more information for you...
I believe they sent you BA XR8 injectors instead of I6 injectors...so really, you just made a profit ![]() http://cgi.ebay.com.au/FORD-BOSS-5-4-V8 ... 7241QQrdZ1 http://www.bosch.com.au/content/languag ... ectors.pdf phong =P~
Froudey |
au injectors are completely different from EF/EL (the outside) it is way smaller in diametre and that..
you will spot the different
fiftyone |
{USERNAME} wrote: Found some more information for you... I believe they sent you BA XR8 injectors instead of I6 injectors...so really, you just made a profit ![]() http://cgi.ebay.com.au/FORD-BOSS-5-4-V8 ... 7241QQrdZ1 http://www.bosch.com.au/content/languag ... ectors.pdf phong =P~ ok, so they are a much bigger injector. the guy says Quote: hi,series 1 and 2 , two part numbers, but can use
it is 0280158188 same flow.thanks ausjap - ausjap123 they have the four hole pattern in the tip however need 4 bar pressure to operate right! does that mean that the car will run as rich as hell because it wont be able to tune around it or is that about what the specs on an au one are? thanks for the find phong!
phongus |
I'm not sure about it running rich. But from what I can make out is that the one you got requires 1.3 bar more of pressure to work at it's potential. I don't think the fuel regulator will allow enough pressure to reach 4 bar, but i could be completely wrong because I am unsure with fuel delivery and fuel regulator functions.
I would think you'd run lean since the injectors aren't fully pressurized. but now I am just guessing... and no problems ![]() phong =P~
fiftyone |
ok, the EL injectors are about 19lb/m
the Au's are 20lb or so a min these that i have are 32lb/m! as a scenario, i have a 275kpa reg ready to go in, a full exhaust and a set of 4480 extractors. if it was your car, would you put them in?
phongus |
{USERNAME} wrote: ok, the EL injectors are about 19lb/m
the Au's are 20lb or so a min these that i have are 32lb/m! as a scenario, i have a 275kpa reg ready to go in, a full exhaust and a set of 4480 extractors. if it was your car, would you put them in? Personally I wouldn't I'd go as far as AUs, mainly because I have been told that they work just fine in the EL engine. Haven't heard of anyone using those ones (which I'll assume are BA ones) on an EL. I think 32lb/min would be good if you have an upgraded fuel pump, fuel reg to make the most of it on a boosted application. For safety's sake, I'd just stick the AU ones in, which I should be doing sometime soon. phong =P~
fiftyone |
my msg back to seller >>>
Quote: I would like to draw your attention to the injectors you have sold me (bosch 0280156186) they are not actually for an AU falcon. they are rated for a BA XR8 (an example here http://cgi.ebay.com.au/FORD-BOSS-5-4-V8 ... 7241QQrdZ1)
these injectors are capable of 300rwkw and as much as i would like my car to produce that, i do not have a 4 bar fuel pressure regulator to supply the required pressure to run them. these injectors also flow at 32lb/m where as i need around 20lb/m (bosch 0280155844) as they are also for a v8 (which i dont have) it makes them useless to me. i would like to return them and get my money back immediately. if it happens with out delay i will still leave positive feedback. please call me at some point tomorrow on 0407090763 to sort this out. Cheers Dave i can't use them and i'm interested to see where this leads. unfortunetly i can't open a dodgy item report till a few days after. if worse comes to worse, i guess i'll sell them as a set for a boosted app or something
phongus |
Well you could ask him to trade it for a set of AU injectors...and they should pay the postage for you since they are the ones that stuffed up.
phong =P~
