Nigel |
Guys. Im after a Mandrel intake for the EF, with the bend all the way to the intake (not using the EL peice).
Does anyone know who in Brisbane will do these? - a good exhaust shop? The one I normally use doesnt do them. Nigel |
krisisdog |
If they can weld then they can make them.
All you or they need is a box of pre-bent mandrel bent pieces of pipe, then they add straight bits where needed and weld it all up. Any good exhaust place should be able to do this. |
Nigel |
Agreed - but seems that a lot of places dont want to do it.
FordFairmont |
its a little more than that.
a few pieces will need to be cut & welded on an angle to get the right shape. Your looking at a bit of money for someone to create a good design, plus for the stainless pipe |
Nigel |
I was looking at potentially using normal exhaust pipe - and painting.
Not after the under bonnet look. |
FordFairmont |
mild steel goes rusty inside, hence why i wouldnt use anything but stainless
60IOW |
I have a full custom 3" mandrel bend pipe on mine that swings right around from the throttle body to the airbox , Dilfillpo in perth im pretty sure made it ... but im sure u go onto the Dilfillpo website and they have them on there ....
_________________ Custom EF , Full Venom BodyKit , Slammed On custom Suspesion , Full White Interior Retrim , Fully worked motor and Fully Detailed , 18" Vault Crystal Rims , Custom Exaust System , Fusion NV15" Subwoofer With a Mono Block 2500 Watt NV Amp In Full Custom Enclosure ... |
Nigel |
Hmmm... $395 + $40 shipping.
low_ryda |
something like this one eh....
{DESCRIPTION} this took me bout half a day to nut out and purge weld. all 316 s/s. silicone tube sections are not fkn cheap! at commercial prices for labour & parts i can see where defilipo gets their price from, not that i agree with it. if your going to make more than one of something you can make jigs,buy in bulk etc it's called production < meant to reduce price.
xpnutter |
if you have no luck in getting one yet try rob bliss exhausts, if they dont do it the inly thing i could reconmend is buy a doughnut(its a mandrel bent bent ring) an buy a metre of straight pipe an go to an engineering work shop, they arent that hard to make it just takes time to cut every thing right the first time
kstevo |
There is a good offer still up for a piece that uses the EL adapter.
For $150 inc. postage you cant really go wrong when you would be looking at at LEAST $200 for an exhaust shop to do one, probably around the $250 mark is what they'd charge you. Here's a link to the thread: http://www.fordmods.com/forums/fs-fs-ns ... 69108.html
_________________ USER BANNED |
Nigel |
I was completely aware of the group buy. Ive now got something made up, total cost $80
Froudey |
{USERNAME} wrote: I was completely aware of the group buy. Ive now got something made up, total cost $80
pics
Nigel |
Work still in progress - doesnt rattle, but will be getting two mounts welded on to retain it anyway. Will also get a tidy up and paint.
alfy |
i like the look of that one Nigel. is it anymore responsive than the standard intake?
_________________ 2021 V6 Manual Amarok - 245kw/750nm - many goodies |
