magna |
hey all, i'm nearly done putting climate in my EF XR6
![]() ![]() i reckon the ECU is faulty can I plug in any ECU from a EF? and will my car start? thanks heaps. |
gogetta |
yes u can...
but why not have a look at the evap sensor
magna |
{USERNAME} wrote: yes u can... but why not have a look at the evap sensor i tried, i unplugged to old one from behind the glove box and plugged another one in and left it hanging out just to test but same error ![]() |
magna |
ok i took a bit of a gamble and got another ECU from the wreckers, i couldn't remember the catch code, but got sold a 4TBD when mine was a 4TDB
![]() plugged it in and voila! problem solved ![]() |
magna |
ok boys, i pulled the old ECU apart and had a bit of a brainstorm
fiftyone |
unless its something on the board itself, the j3 reprogram thing is an option
magna |
{USERNAME} wrote: unless its something on the board itself, the j3 reprogram thing is an option yeah the board is stuffed cause i plugged in a Fairmont Ghia ECU and the error code went away. with the J3 chip i need another ECU anyway so im thinking it's worth a shot. if it works then i've got a spare. |
fiftyone |
in that case, either get an ecu off a ef and reprg it to what ever you want, or get a ef that is similar to what you need. dont go pulling bits from one to the other
