EL ECU in EB Auto - Problems
Page 1 of 3 [ 32 posts ] Go to page 1, 2, 3  Next
 Post subject: EL ECU in EB Auto - Problems
Posted: Sun Jan 18, 2009 6:14 pm
Ride: Supercharged EF Fairmont
Hi there,
Put an EL Auto ECU into an EBII (w/ Smartlock) Auto today. Found that it runs the fuel pump constantly (even when in on, does this past the normal priming) and will start only in Limp Home mode (10deg timing, high idle, loads of fuel).
Any ideas as to why? My only guess is that the ECU may be faulty, but thats a long shot. Anyone done this in an Auto before with some tips?
EDIT: Updated post below, originally a faulty ECU was causing LOS mode, still having problems with the Auto however
Cheers,
Jason
Posted: Sun Jan 18, 2009 6:39 pm
Ride: Boxcar Love
BENJ did this same conversion early on in his Sedan build, and i dont think there was such a problem. Along with other people that have done it i know of. Maybe it could be faulty ecu.
Commodore australia's favorite car??? What a load of s**t
 Post subject: Re: EL ECU in EB - LHM
Posted: Sun Jan 18, 2009 8:38 pm
Ride: 96 XH/97 EL
LHM is in third gear & unlocked - I assume you mean LOS (limited operating strategy). This IIRC is bugger all advance, injectors pulsing every cycle. It is most likely as you guessed a faulty ECU, as an internal fault usually causes it.
You'll have already guessed to fit another EL ECU - there plentiful and usually cheap.
Posted: Sun Jan 18, 2009 9:57 pm
hm. will have to find another ECU. not happy, wanted to wire this car up with ECU controlled thermos.
Posted: Mon Jan 19, 2009 9:57 pm
Ride: EL fairmont offroader
I did that by sourcing the wiring/relays/fuse from an EL, and they work fine to my knowledge.
wrecking 9/97 EL fairmont sedan burgundy 6cyl auto 270k modBAintake
Posted: Mon Jan 19, 2009 10:09 pm
Yeah, it must be the ECU. Put up a wanted ad, if anyone has one kicking about ill trade you a 6 pack for it :)
Have the fan relay loom already.
Jason
Posted: Tue Jan 20, 2009 10:53 am
Ride: BF XR6 Ute
there are a few on ebay atm
BF XR6 Ute,ED XR6 Manual (SOLD),XD 4V 351 toploader 9in
Zoom and Extreme magazines Production Editor
Posted: Mon Jan 26, 2009 10:17 pm
Got another ECU and quickly plugged it in to test it today. It ran fine - first one must have been a dud.
Cheers for the replies.
Jason
 Post subject: Re: EL ECU in EB Auto - Problems
Posted: Mon Mar 02, 2009 11:50 am
All,
This conversion is still not 100%. The car is running the original EB auto and with the EL ECU is doing some odd things.
1. It will hold first until 4 grand on mild throttle then slam into 2nd. It seems to do this more when cold.
2. It will kick down very oddly from what seems to be 4-3-2 on mild throttle when going up a hill. It kind of flares then goes into gear then out then back in.
3. It will sometimes flare on a kickdown from 4-2 on heavy throttle at say 70km/h then slam into 2nd.
None of these traits are present when running an EB ECU, which rules out a faulty trans.
Has anyone done this conversion in an Auto with an original transmission - i.e. not with a newer trans? I know there are minor differences in the transmissions from M91 to M93 but I thought none were electrical.
Any help appreciated.
Jason
Posted: Mon Mar 02, 2009 6:39 pm
Ride: Boxcar Love
I'm pretty sure when Benj done it originally to the red sedan, it still had the EB auto. Maybe shoot him a PM, i can't remember there being a trick to it or anything. :)
Posted: Mon Mar 02, 2009 11:30 pm
Hi.
When I installed the EL GLi ECU in my EB while running the EB Engine and EB Auto, I had no issues at all with shift changes etc. It all worked as it should.
Later I added the EL engine and EL Ghia ECU, still with the EB Auto, and again no issues at all with the ECU or the auto changes.
BenJ
{DESCRIPTION} - Current Ride
{DESCRIPTION} - Previous Ride
Posted: Tue Mar 03, 2009 6:27 pm
Ride: Peacock EB Falcon
What you seem to be describing is pretty much my exact same problem.
Posted: Tue Mar 03, 2009 7:32 pm
Is your car an EB2 as well?
Bens original car was an EB1 - this might have something to do with it.
Hopefully we can get to the bottom of it. Surely more people than just Ben have done this?
Cheers,
Jason
Posted: Tue Mar 03, 2009 8:03 pm
Mine is an EB 1.
I did the transmission wiring conversion for the EAs/EB1's (the auto is controlled by the BEM instead of the ECU). KOEO comes back with fan errors as I'm running a temp switch and still haven't hooked up the EL wiring. Will do KOER tommorow afternoon as I ran out of light.
Posted: Tue Mar 03, 2009 8:28 pm
Ride: Boxcar Love
I'm pretty sure bens EB sedan was an EB2, his wagon is an EB1
Users browsing this forum: No registered users and 28 guests
It is currently Thu Jul 17, 2025 1:20 pm All times are UTC + 11 hours
