BA turbo missing badly when go above 2500 RPM
 Post subject: BA turbo missing badly when go above 2500 RPM
Posted: Wed Jul 20, 2011 6:24 pm
Ride: BA XR6 Turbo
Hi,
I got a BA XR6T it was running fine until last week when it suddenly started missing when it goes into boost . It behaves like its running out of fuel when goes in boost. anyone had same problem??
Its got
4" dump pipe
Hi flo cat
42lb injectors
fuel pump
inter cooler.
Any Ideas
 Post subject: Re: BA turbo missing badly when go above 2500 RPM
Posted: Wed Jul 20, 2011 6:30 pm
Ride: AU XR8
without knowing its history i would say its due for new coils...
Posted: Wed Jul 20, 2011 9:20 pm
Ride: FORD FE LTD TURBO/ XE TURBO
If on petrol, rare it would be the coils. Not to say that it isn't. Check your fuel filter though. Check plugs too. If you've made mods without tune, I'd get on top of that
Posted: Wed Jul 20, 2011 9:28 pm
Ride: 1993 EB XR8
BA will not run with 42's unless it's tuned. Coils are a common BA problem too.
It is currently Fri Jun 20, 2025 2:58 am All times are UTC + 11 hours
