Au vortech supercharged
Page 1 of 1 [ 6 posts ]
 Post subject: Au vortech supercharged
Posted: Sat Sep 14, 2013 3:38 pm
Ride: EF falcon
Will my supercharged au Tickford 4.0 lean out at high rpm running 9 psi boost with 1080cc injectors and a 300 kpa tick fuel regulator ?? Any help would be great cheers
THIS IS RUNNING THE STANDARD TUNE FOR THE CAR !!
 Post subject: Re: Au vortech supercharged
Posted: Sat Sep 14, 2013 5:17 pm
Ride: EF Fairmont
It won't run with a Std tune and 1000cc injectors, it will flood at idle. Wiii overfuel like crazy. You use 1000cc on cars pulling 400rwkw and more with a tune.
You will need a tune and use a BA XR6 Turbo reg. 42lb or 60lb will do you fine.
AU1 or AUII/III?
Posted: Sat Sep 14, 2013 6:16 pm
Ride: EF falcon
Cheers mate . Sorry the injectors I'm running are 440 cc with the 300kpa Tickford fuel reg I'm just gonna be running 9 psi with the standard fuel pump will this lean out ??
Posted: Sat Sep 14, 2013 6:42 pm
Ride: EF Fairmont
They are 42lb injectors, so size is OK. You will still need to upgrade your pump as well as the fuel reg. It will still overfuel on a stock tune with the 42lb injectors.
Is the car AUI or AUII/III?
Posted: Sat Sep 14, 2013 10:25 pm
Ride: EF falcon
Ok , the car is a ef with a au1 motor no VCT
I have a rising rate fuel reg with the vortech charger I will be running this
If need be..
What fuel pump would you recommend ??
Posted: Sat Sep 14, 2013 10:28 pm
Ride: EF Fairmont
Walbro 255
It is currently Sun May 25, 2025 12:53 am All times are UTC + 11 hours
