you guys with superchargers
Page 1 of 1 [ 12 posts ]
 Post subject: you guys with superchargers
Posted: Mon Aug 29, 2005 11:13 pm
a question for the guys with centrivical superchargers
just wanna ask where do u put your air filter.
like i can see in photos the intake piping comin from the back of the supercharger around to the front but then it dissapears behind the head light.
do u but the filter behind the head light or run the pipin down further and put the filter behind the brake duct?
Posted: Tue Aug 30, 2005 12:14 am
Gallery: 9 images
Ride: EF XR8 & 2002 GSXR-1000
Mine sits just behind the hole on the passenger side of the front bar (where I have seen a few people have their fog lights).
Uses some crimped pipe to get there, so it can be flexy if it needs to be as well.
Nice & low to the ground & just behind an opening for the air to come in. Couldn't ask for much more.
The fast fun: Suzuki GSXR1000
The one I use when I can't use the fast fun: Blown EF XR8
Posted: Tue Aug 30, 2005 12:43 am
Ride: 320kw BA XR8
I run mine down in the front spoiler. Cut a hole in the fender under where the factory airbox use to sit and then route the air intake down to the front bar.
Posted: Tue Aug 30, 2005 1:39 am
Gallery: 24 images
isnt there a legal thing of running a pod outside of a box? or is that jsut one of those myths?
Posted: Tue Aug 30, 2005 1:43 am
Ride: 320kw BA XR8
The pod doesn't need to be in the airbox, but I believe it does need to be shielded to be legal.
Posted: Tue Aug 30, 2005 10:57 am
Gallery: 37 images
Ride: V8 EF Futura
Yes my air filter sits where these other two blokes have them mounted. Cut a nice big hole in the sheet metal under the airbox and run some flexipipe down there.
Posted: Tue Aug 30, 2005 12:00 pm
Ride: BA Fairlane Ghia
How do you fellas go with picking up water? is it a problem, someone here has a WRX, blew his donk suckin water.
Posted: Tue Aug 30, 2005 10:59 pm
Ride: 320kw BA XR8
I dont really think water is an issue unless you are stupid enough to drive through deep water. My current setup is fairly low at the bottom of the front spoiler, but unless the water is 6-12" and I drive through it fairly fast I dont see any real issue.
Posted: Tue Aug 30, 2005 11:06 pm
Gallery: 37 images
Ride: V8 EF Futura
My filter is bolted pretty much underneath the passenger side headlight. Whilst i do get a little nervous when theres heaps of water on the road, it would take a serious flood to take a gulpful of water into the engine... my feet would be swimming...
It sits in between the "brake duct" and the headlight.... so it's a good foot and a half off the ground... probably about a foot lower than the standard snorkel...
Posted: Wed Aug 31, 2005 1:34 am
Gallery: 9 images
Never had any problems with picking up water, but I gotta clean the AFS more regularly. It has a tendency to get filthy.
Posted: Wed Aug 31, 2005 1:44 am
Ride: 320kw BA XR8
Here is a pic of my old CAPA setup that sat just below the headlight in the front bumper (front bumper removed in the pic). I have relocated it further down now to give me more room to mount the MAF and larger piping.
Posted: Wed Aug 31, 2005 3:16 pm
Ride: EA falcon
Yep, mines mounted exactly were everyone elses is :)
It is currently Sat May 17, 2025 8:01 am All times are UTC + 11 hours
