source for water to air cores??
Page 1 of 1 [ 12 posts ]
 Post subject: source for water to air cores??
Posted: Sun Sep 25, 2005 12:09 am
I have a Davies Craig booster pump and an old A/C condensor to use as the radiator, I will have a custom reservior made to fit somewhere compact like under boot floor maybe.
Capa have some nice units but seems very expensive.
Anyone know any reasonably priced outlets in Australia??
Or Egay maybe.
Any experiences people have had or estimated costs involved would be helpfull.
Cheers.
Posted: Sun Sep 25, 2005 1:20 am
Power: 482 rwkw
Run two air con condenser coolers cut down to fit in box..
Then run water through both coolers...
As in ZOOM 126 edition
Posted: Sun Sep 25, 2005 1:39 am
Ride: Drives Like Fun
Power: 318 rwkw
Location: Melbourne Interior: Cappucino Exterior: Sparkling Burgundy
I have some cores that I was going to use in a water to air intercooler application - I could get some pics for you for dimensions if you like.
Cheers,
Steve
Posted: Sun Sep 25, 2005 2:59 am
Gallery: 12 images
Ride: 1994 ED XR8 Sprint
wtf? he's trying to cool air, not the water!
Banned
Posted: Sun Sep 25, 2005 12:50 pm
Power: 482 rwkw
Yea dummy he's running water to air RIGHT?
Run cold water through them....
Like I said put these in box or big tube with tanks either side....
Think about it....
The tank and pump can be fitted in boot or over rear wheels...Via radiator to heat exchanger to intercooler & back to tank...
Most of these kits the i/c is fitted under dash....
Similar to this...
Or buy one of these...Not too sure about flow though?
Check thse guys if you don't want to fab your own...
http://www.pwr-performance.com/intercooler.htm
You'll find fabricators in this field are expensive..
Posted: Sun Sep 25, 2005 2:15 pm
Cheers,
Steve
Sounds good, I need something that will support around 1200HP.
Thanks.
Posted: Sun Sep 25, 2005 2:25 pm
Think about it....
Similar to this...
quote]
Yeah that would be ideal. I want to fit mine in the engine bay if possible.
Posted: Sun Sep 25, 2005 2:53 pm
Power: 318 rwkw
Water to air intercooler - that's what he's trying to run is he not ? Google wwater (liquid) to air intercoolers Phil :)
ltd - will get some measuremets for you...dunno how suited they are for 1200 hp...that's a lot of grunt...I'm told they're suited for VG30 application (size wise)...will still find out for you though.
Posted: Sun Sep 25, 2005 6:18 pm
Gallery: 12 images
i know what a water to air intercooler is, just that it's the first time i've heard of a setup like that..... more used to the conventional ones where the air flows through an intercooler core submerged in water
Banned
Posted: Sun Sep 25, 2005 7:22 pm
Ride: xf
that doesnt sound ideal... that would mean that the water would heat up eventually and become less effective would it not???
never really looked into water-air IC's celicas sometimes had them...
try these guyz
http://www.are.com.au/feat/techt/airwaterinter.htm
Posted: Mon Sep 26, 2005 2:00 am
try these guyz
cheers mate, air to air is better for me as i can run ice water and get cooling straight off the line as opposed to a/a as it only cools with speed.
Posted: Mon Sep 26, 2005 2:11 am
Power: 482 rwkw
Subaru Liberty run water to air coolers.Vortech have them too $$$ though...Good for drags but NOT the best for long distance crusing...I'd rather use good intercooler a/a with water/ methonol mix injection...
For drags using dry ice is much easier more efficiant, but you need to make box with fine tubes for engine ..This stuff is bloody cold and there is NO liquide state, its either solid or gas...C02....
It is currently Tue May 20, 2025 11:40 am All times are UTC + 11 hours
