Powerdyne 6psi kit
 Post subject: Powerdyne 6psi kit
Posted: Tue Aug 22, 2006 10:39 pm
Ride: V8
I found this on ebay:
http://cgi.ebay.com/ebaymotors/1986-199 ... enameZWD2V
Would I just need the EB-AU V8 bracket kit from CAPA for $790 in conjunction with this, and bobs your fvckin uncle?
I rang CAPA this arvo and they seemed to think the Mustang bracket is just reversed as CAPA get their kits from Powerdyne.
They then tried to tell me the pulleys and basically everything else in the kit won't fit even though 10 minutes before they said that its the same kit they get.
What do you guys think? Reason being is i don't want to fork out $6,300 for a powerdyne kit from CAPA.
Posted: Wed Aug 23, 2006 11:14 pm
Gallery: 24 images
Ride: VZ SS 6Ltr ute, Honda VFR800
mate i think it would be best to ask this question in the V8 section
My Cars
2006 VZ SS cammed 6Ltr ute 295rwkW
2004 BA XR6T - 290rwkW 12.5@113mph ( SOLD )
1996 EFII Fairmont - 130rwkW 15.5@91mph ( SOLD )
Posted: Thu Aug 24, 2006 12:25 pm
Gallery: 37 images
Ride: V8 EF Futura
You'll need the bracket and the idler pulleys that mount onto the bracket.
You'll need different belts.
You'll need different intake plumbing.
That crank pulley will probably work.
You'll need a tuning solution - chip, aftermarket ecu etc.
I wouldnt run one without a bypass valve.
Running a powerdyne on our engines requires different routing of the belts - check out my user gallery for pics.
So if you start factoring all of that in... you start to see the CAPA system is pretty good value.
If you want to buy from the states, get the blower unit, FMU and build your own kit... as there's a lot in that mustang kit that will end up sitting in the garage forever more.
Posted: Thu Aug 24, 2006 8:46 pm
Ride: V8
Thanks mate thats the answer I was looking for.
It is currently Sat May 24, 2025 5:51 pm All times are UTC + 11 hours
