darkerside |
lets hope someone ,has some ideas .am trying very hard to find who might be able to help locate a manifold that will take an under bonnet blower .here's the hard part
ebs_4l |
the windsor will be pulling vaccum on an eaton m12 wont it?? what sort of flow can they make?? they are out of puff on a v6 at about 250rwkw
_________________ EB 4L, 8.4:1, R154, GT4202r, 4in exhaust, Greenslade Engineering exhaust manifold, plenum chamber, 90mm throttle, Garrett W2A cooler, Surecam custom, autronic SM4, Bosch 120lb, Crane HI-6, LX-92, LM-1, Turbosmart Reg, 2x bosch 044, turbosmart 48 gate. 470kw+ @ 18PSI |
xr8ute |
The Eaton M112 was the blower used on the 03/04 "Terminator" SVT Cobras. The where (by all reports conservatively) rated at 390hp.
An M112 would be OK on a Windsor, but a better option would be a twin-screw blower based kit like those from Kenne Belle. They can move a lot more air for their size before they start to heat things up badly... Are you planning on putting the Windsor into the XB Coupe, or transplanting th blower onto a Clevo? I would expect you will need to have a custom intake fabricate on both accounts. |
4.9 EF Futura |
The KB blowzilla bolts onto the standard intake IIRC
http://www.kennebell.net/superchargers/ ... wzilla.htm The Eaton M90 was used in some 5L mustang applications, 112 would provide plenty of the good stuff for a later windsor. Not much info around on eaton manifolds to suit non-modular ford v8s tho ![]() The guys at pattens might have some tips or maybe CAPA?
darkerside |
xr8:yeah the efi windsor is going into the coupe ,used to have a tidy 400 m,i got old somewhere along the way
