stock internals...5.0...8psi?
Page 1 of 1 [ 6 posts ]
 Post subject: stock internals...5.0...8psi?
Posted: Tue Jun 26, 2007 10:53 pm
Ride: 5lt Turbo NC, TE V6 Gemini
How would a stock EB 5.0 with only cometic head gaskets and head studs go with 8psi? Or 10psi? On a daily driven car, only with the occasional bit of stick? Old man bought a set of manifolds of ebay a while ago, was gunna put them on a mustang, but sale fell through, and he's keen to throw it on the eb wagz?
Posted: Wed Jun 27, 2007 5:42 pm
Power: 482 rwkw
It will take up to 400 rwhp.. With good tune!!
That means atleat 42 Lb injecors and maf..
Along with fuel pump to supply enough fuel .. A Bosch 044 or Walbro 255 ....
You ignition timing will need some attention..
Initial timing IMO start at 4* initial advance...
Yep they go well on 8 to 10 lb...
While heads are off, try machining chambers to lower compression alittle.. 8.8 is about right.. 9 to 1 is alittle high especially with std eec...
Make sure head and block surfaces are absolutley smooth or you'll get leaks....With Cometic gaskets...
The internals / rotating assembly of a healthy 5.0 is much stronger than block!!!!
http://www.turbomustangs.com/stockblock.php
http://www.turbomustangs.com/knowledge.php
Hope this helps...
As in ZOOM 126 edition
Posted: Wed Jun 27, 2007 6:59 pm
Gallery: 30 images
Ride: Blown XR8
The motor will be fine, as long as its in good working order before the blower goes on.
I give mine hell when i drive it around a little. Done well over 100 runs down the quarter mile and she still runs like great. *Touch wood*
Posted: Wed Jun 27, 2007 9:01 pm
thanks guys, games on
Posted: Wed Jun 27, 2007 9:46 pm
Ride: ef xr8
Power: 229 rwkw
How would 24lb injectors go on around 6-8 psi-ish? Car is an auto so it wouldn't see high revs often, saying that would they max out?
Because of Beer, Thirst is a Beautiful Thing!
'95 EF XR8 auto, Advance headers, 3" exhaust, Cobra manifold, BBK 75mm throttle body , 80MM Marauder MAF, Vortech V2 T Trim , 307 rwhp, 405 ft/lb 13.2 @ 105 MPH
Now N/A (permanent Lag) - AFR 165's, Comp XE270 cam, 1.6 RR - 269 rwhp 14.1 @ 102mph.
Posted: Wed Jun 27, 2007 10:02 pm
Power: 482 rwkw
Imo atleast 30 Lb and 36 Lb injectors are cheap as ....
The ignition advance curve is border line and having lean a.f is the last thing you need...
Keep to high impedance injectors and you'll be fine..
Don't go over 65 Lb...
Plenty here to chose from.. it would be far better buying injectors and maf as they should be calibrated to run together...Make sure maf is calibrated for injector flo...
http://www.corral.net/forums/forumdisplay.php?f=323
It is currently Tue Jun 10, 2025 4:24 pm All times are UTC + 11 hours
